Clutch Master Cylinder question-LT1 guys
Old Jun 15, 2007 | 06:43 PM
cwalsh
Guest
Posts: n/a
I have a slight problem. My clutch is slipping when shifting into gear especially at full throttle. When I ease off the throttle & back in its OK. Now normally I would think the clutch is toast but it has only 2500 miles on it. What I did find was that when I remove the clutch master reservoir lid it is spilling fluid out. It seems that something is not letting the slave cylinder release all the way. I also noticed that the fluid is awfully dark as well. The hydraulics were just changed about 1000 miles ago also.
now for that setup: 383 with a T56. Spec stage 3 clutch & Centerforce flywheel. Any particular direction to look.
Chris
Old Jun 16, 2007 | 11:05 PM
fbodyboy's Avatar
make sure that the slave cylinder line is not touching the headers or is to close. I have seen this before on lt1 and ls1 cars. The fluid heats up so much it expands and doesn't compress enough making the clutch feel like its slipping.
Old Jun 18, 2007 | 07:13 AM
cwalsh
Guest
Posts: n/a
I'l look at this tonight if I have time.
Chris
Old Aug 15, 2007 | 08:02 PM
HectorM52's Avatar
Did you solve this problem? What was the issue?
HectorM52
Jan 30, 2015 11:08 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
siguy
Nov 27, 2014 10:07 AM
Red97LT1
Aug 7, 2002 05:45 PM
