4L60E Transmission Problems
Old Jul 2, 2007 | 04:19 PM
yy's Avatar
yy
Unhappy 4L60E Transmission Problems
Hello. I am experiencing a problem of not having overdrive on my automatic transmission. All the other gears work fine without any problems. This is not the original transmission and was rebuilt by another person. When the vehicle is put into overdrive, it will behave exactly as if it is in third gear with the exception when the throttle is let off - the rpm's then settle very low as if it is in overdrive. It was suggested that maybe the previous owner maybe plugged the valve to prevent overdrive from activating. Somehow this is a performance booster? If anyone has any suggestions on how to troubleshoot or repair the problem, it will be much appreciated. Thank you.
Noer
Feb 28, 2015 11:29 AM
jackpawt883
Feb 26, 2015 09:04 PM
edxiel
Jan 24, 2015 07:40 PM
thenewkid
Nov 27, 2014 09:41 AM
Snoman73
Nov 17, 2014 07:22 PM
