Gear Ratio or Speedo?
Old Jun 19, 2007 | 06:11 PM
EScottH's Avatar
Folks:
I noticed since I got my 94 Z in the past month that my speedo seems to be reading slow compared to the other vehicles around me. I got out my trusty GPS to see if I could get an accurate comparison between the speedo and actual.
What I found was if I hold steady at about 50, the GPS reads approximately 60. If I go 60, the GPS reads 72.
Do you think this is a speedo issue or do you think the rear end had been replaced/regeared by a previous owner?
Thoughts?
Scott
Old Jun 20, 2007 | 02:17 PM
2001NBMZ28's Avatar
Compare your RPMs at actual 60 MPH and play with a calculator like www.f-body.org/gears/ Plug in different ratios until it matches. People change gears all the time. I went from 2.73 to 3.42 - but changed the setting in the PCM. You can also get the car in the air and see how many times the driveshaft turns/complete wheel turn - or pull the cover.
anmar A
May 2, 2015 06:59 PM
thenewkid
Apr 12, 2015 07:42 PM
blac94Z
Feb 10, 2015 11:02 AM
Jul 4, 2005 05:00 PM
