Clutch choices.. help me choose
Old May 28, 2007 | 01:46 PM
Roach02's Avatar
Arrow Clutch choices.. help me choose
Okay, I'm replacing the clutch in my 95Z and can't decide on what to go with. I'm in between the Centerforce Dual Friction and a Spec clutch. What do you all recommend and if it's the Spec what stage should I get. The car is just a bolt on car and I don't drive it much at all. So two questions.
1.) Which clutch do you recommend?
2.) Where's the cheapest place to get it?
Thanks in advance
Old May 28, 2007 | 02:06 PM
matLT1's Avatar
I have had good luck with my SPEC Stage 3, but that would be overkill for your setup. If you do go with SPEC, I would recommend the Stage 1 if you have no major mods planned in the distant future or the Stage 2 if you would like to leave some room. The Stage 1 is basically for mildly modified cars, whereas the Stage 2 is good for 500 ft-lbs of torque.
A lot of people complain about SPEC and chatter, but once they break in and you adjust to driving them (people forget these aren't OEM clutches ) the chatter is gone.
Ericksd
Jan 20, 2016 06:07 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
