Neep help really bad might be trans mount
Old Jun 20, 2007 | 03:41 PM
Lt1Power95's Avatar
I have a 95 z28 camaro A4 stock i recently got it rebuilt at aamco transmissions and since ive been through 2 torq converters and 2 trany mounts. Now i am having a problem when i smoke my tires from idle it feels like my rearend is going to brake or something it only happens when i smoke my tires from idle i can feel it under my leg by the transmission. in normal driveing conditions it feels fine it chirps through the gears and i dont feel no clunks or anything. when i step on the brake and smoke my tires its fine its only when i put alot ot torq on the trans from idle does that sound like my trans mount again it looks fine i cant see any cracks or anything from under the car but i really can't see everything or all around it please any suggestions would be greatfull
Old Jun 20, 2007 | 07:41 PM
Lt1Power95's Avatar
anyone
Old Jun 20, 2007 | 10:26 PM
'94 Bad A Z28's Avatar
Just pull it out and see for sure, it takes what 5 mins. My poly mounts always "look" fine but then I drop the crossmember and the mount falls into two pieces.
Old Jun 21, 2007 | 02:03 PM
11secgen's Avatar
if you have the rubber motor mounts ,youll break your poly trans mount more often.the rubber motor mounts alow for alot of movement, but the poly trans mount wont alow the engine/trans to move,so the trans mount will break.get a big pry bar and put it in between the tans and crossmember, prying up on the trans.any movement and the mount is broken.go with poly engine mounts and this wont hapen.you may have a bad motor mount anyways,that will also kill the trans mount.
Old Jun 21, 2007 | 06:44 PM
Lt1Power95's Avatar
mount
i just replaced my mount with a poly. But still am having the same problem could it possibley be my panhardbar i just installed i dont think it did that when i had my stock one's on and also i have not greased it or anything i still need to buy a grease gun to put some in there
Thnaks, Ryan
HectorM52
Jul 30, 2017 11:46 AM
Jun 6, 2015 08:27 AM
Jan 5, 2015 07:14 PM
mattszm6
Dec 14, 2014 07:09 AM
x7x7
Aug 15, 2002 06:49 PM
