Need flywheel help!
Old May 29, 2007 | 12:54 PM
Roach02's Avatar
Question Need flywheel help!
Okay I'm getting ready to put a Spec Stage 2 Clutch in the car and I'm wondering about the flywheel. Should i just resurface the stock one or purchase a new one. The guy that's doing the install works at a chevy dealership and he recommended purchasing a new one. I'm just wanting to know if an aluminum one is worth the extra cash and do I need to get it balanced if i do get a new one and how do i do it or where can I have it done at?
Old May 29, 2007 | 01:52 PM
95LT1conv's Avatar
just get the stocker resurfaced. You would have to have the new setup balnced to the old one. Good luck w/ the Spec. IMO the royaly suck.
Old May 29, 2007 | 02:16 PM
ConElite's Avatar
SPEC is a good company. I love them. They hold real hard. If your going to do alot of autocross then get an aluminum FW. If not then Resurface the stocker.
Old May 29, 2007 | 02:44 PM
Roach02's Avatar
thanks for the info guys. see i've heard good and bad things about the Spec clutches. I was also looking at the centerforce df as my other choice. Then I noticed the RAM clutches which i've never even heard of.
Old May 29, 2007 | 06:50 PM
matLT1's Avatar
I went with the SPEC Steel Flywheel for my Stage 3 setup. Something to consider is that cast iron flywheels are not the best surface to use with a high friction clutch. I would put money on most of the people on here who have problems with SPEC clutches are running their stock flywheels (somethings not resurfaced ) and have the ***** to blame the manufacturer.
Old May 30, 2007 | 12:09 AM
Roach02's Avatar
you think i would be okay if i just resurfaced the stocker?
Old May 30, 2007 | 03:17 PM
Compstall's Avatar
I'm using the stock flywheel w/ a Spec 3 no problems. 30,000 miles and running strong.
Formula Steve
Sep 19, 2023 08:31 AM
Ericksd
Jan 20, 2016 06:07 PM
karpetcm
Sep 29, 2015 10:08 AM
Jake Bialke
Sep 24, 2015 11:31 AM
Bxlt1
Sep 17, 2015 08:31 AM
