removing the a4 with lt headers
Old Jul 4, 2007 | 12:26 PM
pyro719's Avatar
Do I need to pull my headers to pull my transmission?
Old Jul 4, 2007 | 10:02 PM
12SCNDZ's Avatar
Your earlier 4L60E is a little more difficult because it still has "ears" on the bellhousing. Later models had these cut off. We also cut them off of all our rebuilds.
I believe it will still come out, though. It's just a little tighter.
Frank
CPT
Old Jul 5, 2007 | 01:55 AM
revtime's Avatar
I never had a problem with the 60E clearing my LTs and trust me I had to change it several times.
I also have an ultrabell on my TH400 and had zero issues installing it with the LTs on the car.
Old Jul 5, 2007 | 08:40 AM
smoknta's Avatar
I dont have the 60E, but my 700R4 had no issues coming out, and the TH350 had no problems going in with my Jet-hot long tubes.
Old Jul 5, 2007 | 09:15 AM
matLT1's Avatar
When dropping my 4l60e I didn't have any trouble with my Hooker LT's interfering.
Old Jul 5, 2007 | 09:18 AM
Pro Built Automatics's Avatar
Frank is right, once the ears are gone it is much easier to remove and install. We started doing this modification "cutting the bell housing ears off " back in the late 1970's, and it makes things a lot easier when headers are involved. And yes, there are always exceptions to this, as stated.
Old Jul 5, 2007 | 09:09 PM
pyro719's Avatar
I already cut one ear off my pass side bell housing so it should help a little. I was wondering if the trans hanging off the back when the cross member is removed will damage the headers?
Old Jul 6, 2007 | 03:14 AM
smoknta's Avatar
Block up the motor
Old Jul 6, 2007 | 08:54 PM
pyro719's Avatar
if I block up the motor than I wont be able to get the tranny out.
Old Jul 6, 2007 | 09:17 PM
smoknta's Avatar
Just block it up far enough to where the headers are not hitting the K-member. If you let it hang, the headers will hit the K-member and it will bend them.
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
drptop70ss
May 4, 2015 08:22 PM
R@mpage
Apr 20, 2015 10:02 AM
alphaauto
Jan 23, 2015 07:42 AM
