A4 & single cat. Torque Converter question?
Old Jun 25, 2007 | 11:10 PM
mrmint69's Avatar
Do i have to remove any of the exhaust on my 94? I have mid Pacesetters. I saw someone had to remove the Y pipe but they had dual cats. If you did change it out, would you do it again and was it worth the hassel? What kind of hp difference?
Old Jun 26, 2007 | 12:27 AM
MyShibbyZ28's Avatar
Are you talking about changing to a bigger torque converter? You do have to drop the exhaust a little to take the trans out.
Old Jun 26, 2007 | 04:50 PM
2000GTP's Avatar
Are you asking about the y-pipe, or the converter, I am a little confused. The higher stall converter won't provide any power gains. Adding a different, better flowing y-pipe might though.
Old Jun 26, 2007 | 08:00 PM
mrmint69's Avatar
I guess a don't know the reason for a higher stall converter. What does it do and why do people relace the stock one? The Y pipe with the headers is a good flowing one compared to stock.
Old Jun 27, 2007 | 03:18 PM
People change to bigger stall converters for speed/time reasons. Some TC's will have a torque multiplier that helps. The higher the stall speed, the higher the RPMs will be when the car starts to move, allowing the car to be around the peak (or just below) horsepower. This makes the car accelerate faster on take off due to more power. As for driveability and gas milage is concerned it will not save you any, and will most likely hurt it unless it has lock up (like the factory one).
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
Queens94z28
Dec 20, 2014 09:11 PM
Collector Car
Dec 17, 2014 01:12 PM
squarehead
Nov 21, 2014 08:02 PM
RedLineRev
Jan 23, 2003 03:51 PM
