LT1 Tranny Swap Questions
Old Jul 1, 2007 | 04:34 PM
Sinister95Z's Avatar
Currently I have a T56 in my 95 Camaro. The plan is to do a 4L60e swap in the next couple of months. The major plans are as follows :
Performabuilt Stage 2 or CPT 4L60E Tranny
Higher than stock Stall
All stock conversion pieces including A4 wiring harness (Which I am still looking for)
PCMForLess Reflash of PCM
TCI Flexplate
ARP Hardware
ETC...
I am starting to purchase the parts that I will need little by little to make the swap as easy as possible when it comes time. I have a couple questions that I hope you guys can help me with.
I am placing an order with Summit today for the first couple of parts for the tranny swap and the rest of the parts for my rocker/spring upgrade. Do I have these part numbers correct?
TCI Flexplate PN# 399173
ARP Flexplate Bolts PN#200-2902
What size and part number do I need for the ARP Torque Converter Bolts?
With some modification, which aftermarket shifter will work with the 4L60E?
What size stall would you guys recommend for a daily driven bolt on Z and and the rare 100 shot?
Thanks for any and all help.
Old Jul 2, 2007 | 12:40 PM
I am hoping to place the order today, so any help would be appreciated.
Old Jul 3, 2007 | 07:29 AM
Please?
Old Jul 3, 2007 | 03:50 PM
I guess not.
Old Jul 3, 2007 | 04:15 PM
12SCNDZ's Avatar
Jegs sells an SFI approved flexplate that's a little less expensive.
Many aftermarket converters come with the proper bolts.
The B&M Pro Stick will work, if you buy the optional 4 speed gate plate.
3200 stall is a good converter for a bolt on, DD car.
Frank
CPT
Old Jul 3, 2007 | 05:00 PM
Thank you for the input.
Old Jul 6, 2007 | 10:27 AM
Is there any reason why this flywheel would not work on my LT1?
http://www.jegs.com/webapp/wcs/store...10002_72530_-1
Old Jul 6, 2007 | 11:42 AM
12SCNDZ's Avatar
That is the correct flexplate that you'll need for an LT1.
Frank
CPT
Old Jul 6, 2007 | 01:35 PM
Thank you. That will save me a couple bucks...
rocketman051894
Jan 30, 2015 03:23 PM
cmdeshon
Jan 4, 2015 11:15 AM
nballisru
Dec 14, 2014 05:01 PM
mattszm6
Dec 14, 2014 07:09 AM
Ricardo
Nov 29, 2014 10:58 AM
