is my stall to big?
Old Jul 3, 2007 | 11:13 AM
Wishmaster's Avatar
is my stall to big?
is the stall I have to big for what Ive got?
Im running a 383 with the Holley Stealth Ram intake on the top...I have a custom 226/232 cam with 535/537 lift @50....under my AFR 195's, 30lb SVO's, 58mm TB, Hooker LT's, Spohn PHB, BMR TA, LCA's..SFC's..wide open Borla exhaust
Im running 3.42 gears in the rear behind a 700r4?
The stall Im running now is a Midwest 3400 with a 2.5 str...I havent really had time to get on it or even see what it acts like behind my 383 powerplant....
do you guys think that is to much stall for what I have?
Old Jul 3, 2007 | 11:42 AM
ttop1986's Avatar
No, I run a 3000-3200 on mine and I have stock cam.
Old Jul 3, 2007 | 12:35 PM
Z-RATED94's Avatar
To big, no. Got stickys?
Old Jul 3, 2007 | 12:45 PM
Wishmaster's Avatar
wont I run out of RPM's with the stall being so high? That cam is with 1.5's..I was thinking of going to 1.6's.
Stickys? nope...I will run drag rads....
I havent had a a chance to play with it as its all behind my new motor....and Im having to replace the flexplate cause I didnt locktite the bolts and all of them backed out and egged the holes in the plate....so when I drop the trans..I figured if I had to have it restalled I could do it then.
so you guys think Im ok..with what I have?
Old Jul 3, 2007 | 01:07 PM
Z-RATED94's Avatar
OK, listen up. You have nothing to worry about with 3.42 gears. And if you have DRs, I consider those stickys. If they don't stick, you have a suspension problem. Trust me, your converter is NOT to big.
Old Jul 4, 2007 | 10:48 AM
Wishmaster's Avatar
ok if you say so...it just seems to flash way higher that 3400.....but I really wasnt paying attention...I guess I'll keep what I got..
Old Jul 4, 2007 | 11:06 AM
mdacton's Avatar
where does it flash?
have you had it on a dyno? it should flash abround where your peak tq is
Old Jul 4, 2007 | 11:13 AM
Wishmaster's Avatar
nah I havent had it dyno...but im thinking it flashes somewhere around the 4000 or more mark....
Old Jul 5, 2007 | 02:02 AM
revtime's Avatar
You can't have too much stall.
Old Jul 5, 2007 | 08:39 AM
smoknta's Avatar
3400 is the rated stall. A converter will act differently on every motor because of weight, HP, and torque differences. Your best bet is to call a company and give them all the info on your car and have them build you a custom converter. But no I dont think that is to much stall. I had a 3600 stall made for my car and I could flash it to around 4k. I just switched to a TH350 and I had them rebuild the converter and I had them turn it up just slightly.
NewsBot
Aug 3, 2015 02:40 PM
detroitmuscle
Jul 31, 2015 04:21 AM
Louey
Pacific
Jul 27, 2015 09:58 PM
ricks95TA
Jul 23, 2015 12:59 AM
ricks95TA
Jul 22, 2015 10:15 PM
