that'll do pig, that'll do
Old Jun 18, 2007 | 10:15 AM
bkpliskin's Avatar
hey....
my car is in my sig....I have the interior from a junkyard 97 and it only has 2nd gear written on the shifter cover...but I can put it in 1st gear manually...I just can't see the red strip....does this mean I have 3.23's?
Old Jun 18, 2007 | 10:26 AM
JasonD's Avatar
Admin Emeritus
First, I just don't get the thread title...but anyway...
Second, moved this to the right tech forum.
Third, did you buy your car used? The 1st gear stop may have been cut allowing it to go into 1st gear, something that they didn't let happen on some cars from the factory.
Old Jun 18, 2007 | 10:36 AM
bkpliskin's Avatar
haha, it's from the movie BABE.....
anyway....my car was a 94 V6 and I bought a wrecked 97 Z28 and then got the dash and shifter cover from a junkyard.....so the tranny and the shift cover are from different cars....there wasn't any modification with the wrecked Z28
Old Jun 18, 2007 | 10:53 AM
JasonD's Avatar
Admin Emeritus
Yeah, I know that. I don't see what it has to do with the shift selector on your car.
Some cars had 1st gear locked out, I believe for emissions on V8 cars. Since the gear was locked out, no need to show it on the indicator. Must be V6 transmissions didn't have that lockout, different trans or something.
Old Jun 18, 2007 | 11:28 AM
ZL1modified's Avatar
hey....
has nothing to do with what gears you have... i have a 97 that does the same thing if you pull back enough... just has to do with the stop that they put on... your is either cut or not there...
Old Jun 18, 2007 | 11:33 AM
mdenz3's Avatar
If your rear end is the original one just look at the RPO code(look for gu2 gu3 etc). The best way to be 100% sure is to just take off the diff. cover and look at the gears. Its a good idea to change the fluid anyway.
Old Jun 18, 2007 | 02:04 PM
11secgen's Avatar
to answer your question, a4 do have 3.23 behind them.
Old Jun 18, 2007 | 04:07 PM
2000GTP's Avatar
Check your RPO codes, easy way of knowing if you have 2.73s or 3.23s.
Old Jun 18, 2007 | 04:32 PM
'94 Bad A Z28's Avatar
All that means is that the previous owner removed the stopper that blocks out 1st gear on 2.73 cars.
Old Jun 19, 2007 | 03:44 PM
bkpliskin's Avatar
.................................................. .I do not have the codes because I do not have the doors from the car that all the guts came out of.....my car was a V6.....so all my codes are just going to be 94 V6 codes on the door panel.....second.....the shifter cover that is in my car now was not from my orignal V6 nor was it from the car we took the guts out of....it's just a random piece from a junkyard.....so just because it doesn't have a 1st gear selection on it doesn't mean my tranny had the 1st gear lockout....
I just need to know.....do all the ones with 2.73's have 1st gear lockout? and if so, why would they lock out first gear in a car with 2.73's and not 3.23's? Did all 3.23 cars have a selectable 1st gear from the factory?
Old Jun 19, 2007 | 04:40 PM
JAB's Avatar
JAB
Yes, 3.23's had a selectable first gear. 2.73's did not.
Old Jun 20, 2007 | 02:03 AM
LSWHO's Avatar
Holy crap. You guys telling me I DO have a first gear to go into in my car?!? How do I go about doing this?
Old Jun 20, 2007 | 04:10 PM
Lift your shifter plate up and you will see a blocker going across the selector "nubs" (don't know how else to say it, you'll see what I'm talking about), remove this blocker (break it off) and there you have it, selectable 1st gear.
Old Jun 20, 2007 | 04:21 PM
LSWHO's Avatar
AWESOME. Thanks dude.
grabbem88
20
Dec 27, 2015 07:42 PM
grabbem88
Apr 16, 2015 06:57 PM
blac94Z
Mar 20, 2015 09:58 PM
grabbem88
Mar 18, 2015 01:25 PM
slvrbird2000
West South Central
Feb 22, 2003 05:03 AM
