torque arm instalation
Old Jun 2, 2007 | 08:58 AM
Garcia95's Avatar
how do u put the torque arm back on the car. took it of to overhaul the tranny now i cant put it back on. i cant get it aligned to bolt it on to the differential.
can someone help me.
Old Jun 2, 2007 | 09:49 AM
CamaroBoy96Z28's Avatar
It can be a huge pain to get on either way but I bolt it to the rear end first then push up on the tip toward the tranny to get it into the clamshell mount. Takes a few minutes that way.
Old Jun 2, 2007 | 09:59 AM
Garcia95's Avatar
thanks man ill know for next time i have to remove it.
Old Jun 2, 2007 | 02:47 PM
2000GTP's Avatar
I found that making height adjustments with the floorjack helps to line up the bolts as well.
Old Jun 2, 2007 | 03:20 PM
Garcia95's Avatar
thanks
Old Jun 2, 2007 | 04:14 PM
chevynutman's Avatar
for the future,you don't have to take it off the rear end to remove tranny just unbolt from tranny and let it rest on floor pan and when you put it back in pull it down into mount--if nothing else works you can remove shocks and springs then you can turn diff, easier
Old Jun 3, 2007 | 08:26 AM
Garcia95's Avatar
nice
Old Jun 3, 2007 | 12:35 PM
JimboManJones's Avatar
What I do is place the edge of the jack as close to the rear end cover as possible(as far away from the u-joint as possible towards the back of the car), and jack it up only alittle, then pull down on the u-joint to align it and slide the torque arm over the rear.
The closer the edge of the jack is to the cover, the more leverage you can get when pulling down on the u-joint and it'll make it easier to get it at the right angle.
Don't jack the rear up too much cause it the jack slips off the end and the rear falls down and hits you in the head, it could ruin your day.
Old Jun 3, 2007 | 03:55 PM
Garcia95's Avatar
thanks for the tips u all
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
canbaufo
May 5, 2015 03:43 PM
Jason Short
Jan 19, 2015 06:34 PM
