A4 Broken
Old Jun 22, 2007 | 10:08 AM
SApat's Avatar
A4 Broken
I recently upgraded my rear lower control arms to prevent diff hop.
This mod worked well & launching under stress did not produce any hop.
Then the rear Gearbox mounting failed - repaired
Now the A4 only engages park & reverse - no forward drive in any gear.
I have checked the fluid levels , shifter cable & the arm moving the selector shaft. Next I will remove the converter cover & oil pan.
The car is 1994 Camaro 5.7 V8
PLEASE HELP
Any advice on how to fault find & repair the problem will be much appreciated
Patrick
Old Jun 22, 2007 | 10:57 AM
Performabuilt's Avatar
Supporting Vendor
PLEASE HELP
Patrick
If the car will go in reverse but has no forward gears. You have and internal transmission issue.
Old Jun 22, 2007 | 08:12 PM
12SCNDZ's Avatar
Most likely the aluminum forward piston has cracked. This is a pretty common problem with the 4L60E transmission. It's the reason we upgrade to steel pistons in the input drum. If you need anything, please feel free to give me a call. 302-250-1202
Frank
CPT
Old Jun 23, 2007 | 03:40 AM
SApat's Avatar
Do I need to remove the gearbox to install the piston ?
What is the cost of a steel piston ?
Are there any other parts required for this upgrade ?
Thanks for your help so far
Patrick
Old Jun 23, 2007 | 09:51 AM
12SCNDZ's Avatar
Yes, the transmission has to come out. Most likely, the forward clutches will need to be replaced as well. To completely update the transmission, we install the steel 3-4, forward, and over-run pistons and the 2 associated spring packs. The cost of the kit is right around $50.
You'll also need a spring compressor to get the drum apart. It'll also require a pair of 90* snap ring pliers, a lip seal tool, metric sockets, and a flat screwdriver. To put the transmission back together, you'll need a pump gasket, pump o-ring, servo cover o-ring, and a pan gasket. I'd suggest getting a new set of 3-4 clutches and steels, as well as a new 2-4 band. Both will probably be worn. I'd really suggest changing the filter, too.
Frank
CPT
mmf_1013
Sep 12, 2015 08:56 PM
Toxintwins
Sep 11, 2015 11:13 AM
mlopezart
Sep 8, 2015 12:15 PM
maverickmk
Sep 1, 2015 09:17 PM
Fastbird93
Jul 11, 2015 04:37 PM
