6 speed differance
Old May 28, 2007 | 04:41 PM
Daniel6718's Avatar
6 speed differance
i know the 93 have a differant 6 speed...what about vettes...are they differant from f-bodys?
Old May 28, 2007 | 09:32 PM
The 4th Gen Corvettes used ZF 6-speeds, not the Borg-Warner T56. Different trans, made in Germany. Similar gear ratios, and had the skip-shift feature used on the T56 from 94 up.
Old May 29, 2007 | 01:36 AM
Daniel6718's Avatar
are they interchangable?
Old Jun 26, 2007 | 07:32 PM
tnmotown's Avatar
i know im kinda bringing this up from the past, but..
yes they are interchangable. I just put in a T56 in my '94 Z28. The T56 came out of an '93 Z.
Now the speedo is off and i think because the gearing is different.
Oh well, just send it out to Ion.
Old Jun 26, 2007 | 08:34 PM
karpetcm5's Avatar
^^^ it is different
Q: What are the stock transmission gear ratios and torque capacities?
A: The following were available by year:
Year Model/Optn 1st 2nd 3rd 4th 5th 6th Final
1993 Manual/M28 3.36 2.07 1.35 1.00 0.80 0.62 2.73 (GU2)
1993 Manual/M29 2.97 2.07 1.43 1.00 0.80 0.62 3.23 (GU4)
1993 Auto/MX0 3.06 1.63 1.00 0.70 -- -- 2.73 (GU2)
1993 Auto/MX0 3.06 1.63 1.00 0.70 -- -- 3.23 (GU5)
1994 Manual/MN6 2.66 1.78 1.30 1.00 0.74 0.50 3.42 (GU6)
1994 Auto/MX0 3.06 1.63 1.00 0.70 -- -- 2.73 (GU2)
1994 Auto/MX0 3.06 1.63 1.00 0.70 -- -- 3.23 (GU5)
The '95s and later have the same ratios as the '94s. Aside from the CAGS provision and different gearing/input shaft (on the post 93's), all of the 6-speed transmissions are basically the same.
__________________
karpetcm5 is online now Report Post Edit/Delete Message
Old Jun 27, 2007 | 11:30 PM
I think he was asking if the ZF 6-speed would interchange with the T56. I think the clutch would have to be swapped as well, since the T56 used in the LT1 F-Bodies used the "pullback" clutch design.
The fact that the 93 T56 has different tranny gear ratios, and the fact that the 93 M6's came with different rear axle ratios is not what is producing the error in your speedo. Its a difference in the output pulses/mile on the VSS sensor. Was you 94 originally a T56 or a 4L60E?
Old Jun 28, 2007 | 02:12 AM
tnmotown's Avatar
it was originally a T56. I just swapped it out and put a '93 transmission in my '94
Old Jun 28, 2007 | 10:24 AM
karpetcm5's Avatar
I did the exact opposite i took out my 93 6speed and put in a 95 6speed and my speedo was way off.
Old Jun 28, 2007 | 10:31 AM
tnmotown's Avatar
karpetcm5, what did you do to correct your speedo problem?
Old Jun 28, 2007 | 01:55 PM
The problem would be the number of teeth on the reluctor gear on the tranny tailshaft. I believe jagsthatrun.com has info on how to correct the problem.
http://www.jagsthatrun.com/
Old Jun 28, 2007 | 05:21 PM
karpetcm5's Avatar
I did nothing, my speedo has never worked correctly in any of the 3 camaros ive had so to me i look at gear and rpm to figure out how fast im going. Im use to it by now after 10 years.
Old Jun 28, 2007 | 05:39 PM
tnmotown's Avatar
lol, if that works for you that cool. I personally like to know how fast im going and usually on the highway i know what gear to downshift depending on my speed.
DirtyDaveW
Dec 1, 2016 05:37 PM
REDNECKISBOSS
Apr 17, 2015 07:14 AM
Z28amustangklr
Middle Atlantic
Mar 28, 2015 03:08 PM
karpetcm
Feb 9, 2015 09:21 PM
Jul 4, 2005 05:00 PM
