think i messed my clutch up
Old Jun 22, 2007 | 10:59 PM
Purplemaroz28's Avatar
Taking my car for a spirited ride, when i shifted into second from 3rd, just reved up and locked me out of every gear, then i coasted turned it off and then put it in gear with a strange ticking noise coming from the tranny, a very fast repetive ticking noise. will not move so have to have it towed to a friends house.
so my question, is it the flywheel or the whole tranny?
will be pulling tanny soon any advice?
Old Jun 23, 2007 | 01:19 PM
30th6's Avatar
you can change gears without using the clutch just get your rpms right.try to see if you can go through your gears.
Old Jun 25, 2007 | 04:16 PM
when its in gear it doesnt move, no power is being transmited. but it will go in gear.
Old Jun 25, 2007 | 04:44 PM
ulakovic22's Avatar
When it's running will it go into gear? If it does, when you let the clutch out does it not move at all, you rev it and it just revs like in neutral?
Old Jun 25, 2007 | 05:26 PM
when u put it in any gear, let the clutch out, it will not move, it just makes a ticking noise, when in gear.
Old Jun 28, 2007 | 10:42 PM
ulakovic22's Avatar
Have you been able to work on it yet? Sounds like you burnt the clutch up and possible the ticking noise is the clutch and PP rubbing.
Old Jun 29, 2007 | 03:10 PM
yep took it all apart it was the pp, totally twisted the middle section out and broke the pp in half. Ordered a mcleod st, should be in shortly, when i get a camera ill take pictures of the destruction.
it looks like the throwout bearing got jammed in the flexplate, and i had to pull the clutch fork out to get the tranny out is thi normal?
Old Jun 29, 2007 | 03:12 PM
ulakovic22's Avatar
Yeah, that's normal. The TO bearing is part of the PP.
Old Jun 29, 2007 | 03:17 PM
first time doing it, kinda had me scared the input shaft was twisted in the motor
Old Jul 3, 2007 | 07:59 PM
still waiting on the clutch
Ericksd
Jan 20, 2016 06:07 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
Ericksd
Sep 16, 2015 07:08 PM
