How do i correct my speedometer!?!?!
Old Jun 26, 2007 | 11:41 PM
tnmotown's Avatar
I just put in a t56 tranny into my '94, and i believe it came from a '93. Now my speedometer is off. It reads 40mph when im on the highway. I need to check the tag to see if its the M28/M29.
Anyways, how do i correct the speedometer? Is there something in the rear of the transmission that i could change or should i have my PCM sent out to get re-programmed?
Old Jun 26, 2007 | 11:45 PM
ttop1986's Avatar
Program the PCM.
Old Jun 27, 2007 | 12:03 AM
tnmotown's Avatar
yeah, that might be my easiet thing to do
Another question on the '93 tranny. I swapped my Skip shift eliminator plug and put it in a connector, thinking it was the CAGS solenoid. Did i put the plug in something else? It did seem like i had an extra connector hanging around.
Old Jul 1, 2007 | 01:23 AM
Jared 3870's Avatar
The '93 T56's (both the M28 and the M29) didn't come with the skip shift option. So I don't know what you have plugged in where, but its not right.
Old Jul 1, 2007 | 03:25 AM
bombebomb's Avatar
Yea, need the pcm reprogrammed, im in the same boat as you needing the speedo fixed, mine reads 80mph when im going 55.
Old Jul 1, 2007 | 10:49 PM
Did you check out "jagsthatrun" to see if its a difference in the number of teeth in the VSS reluctor gear on the 93 T56, compared to the 94-and-up T56?
http://web.camaross.com/forums/showthread.php?t=523521
Old Jul 1, 2007 | 11:35 PM
tnmotown's Avatar
i checked out jagsthatrun.com, so do i need the T56 40-Tooth Reluctor Ring
Part # T56-001? If so where does that part go and is it hard to put in?
Aaront810
Aug 29, 2020 09:34 PM
drt
Sep 27, 2015 04:39 PM
Fatdog2
Sep 16, 2015 11:04 PM
tommalcolm
Sep 11, 2015 03:39 PM
RubyRedIrocZ
3rd Gen / L98 Engine Tech
Sep 10, 2015 01:48 PM
