Clutch disengage problem
Old Jun 18, 2007 | 05:28 PM
Wraith's Avatar
Question Clutch disengage problem
I did a search and didn't find anything like this in any results. While driving I was approaching a stop light and pushed in the clutch to which I started getting a ton of chatter and vibration in the pedal itself. I immediately placed the car in neutral and let off the clutch. No noise, no vibration.
When I began to start again, I pushed in the clutch and felt tons of chatter and pedal travel was minimal. I backed off, car still in neutral and pushed again with the same result. It killed the car trying to push the pedal much past the beginning of the chatter. I restarted and upon only putting the pedal 1/4 down from normal I was able to get the car in gear and get going. I could only short shift like this and was able to make it home.
It's a McLeod twin disk kit, brand new and I used their master cylinder. I have about 9K on it. I haven't done any 5K dumps, no drag strip, and I haven't run over anything. Any ideas?
Thanks in advance.
Old Jun 19, 2007 | 11:19 AM
Jazsun's Avatar
Thanks in advance.
Only real thing you can do is check the clutch fork, besides that hte trans is gona have to come down.
BigWil
Mar 29, 2015 12:24 PM
BPS
9
Mar 5, 2015 10:51 PM
eazyZ
Mar 1, 2015 07:12 AM
HectorM52
Jan 30, 2015 11:08 PM
siguy
Nov 27, 2014 10:07 AM
