turbo 375?
Old May 28, 2007 | 08:40 PM
93v8clone's Avatar
turbo 375?
has anyone ever run this tranny in a 4th gen f-body i have some questions on it i know its basically a th400 with a th350 output shaft and a long tail tailshaft but how are they good or ****ty
Old May 29, 2007 | 12:21 AM
Performabuilt's Avatar
Supporting Vendor
Mechanically they are as you said a 400 with a 350 output spline , Other than that they are a th400
Old May 29, 2007 | 06:22 AM
Pro Built Automatics's Avatar
Pretty much as Performabuilt says, they are a "mid length" TH400 with a TH350 output splines. You can modify them the same way as the TH400.
Old May 29, 2007 | 08:13 PM
93v8clone's Avatar
cool cause my 4l60 is startin to slip like a boeotch on the 1-2 shift and i really dont need a 4 speed so this will work
Old May 29, 2007 | 08:27 PM
12SCNDZ's Avatar
What are you going to hook your torque arm to? How are you going to run your speedo? What crossmember are you going to use? Obviously, you're going to need a custom driveshaft. The 700 has more benefit than just over drive. It also has a lower (3.08) first gear, which makes it superior over a 400/475/375. The 400 will also eat more HP. Your car will most likely 60 ft. worse and run slower with the 400/475/375.
The 700/4L60E have gotten an undeserved "bad wrap". Mostly due to people THINKING they know how to build them.
Frank
CPT
Old May 30, 2007 | 08:16 PM
93v8clone's Avatar
im just ordered the bmr floor mounted adjustable trq arm dont care bout speedo <for now> and i need to shorten d-s 3 inches and i welded a tab and bracing for the crossmember
95blkss
Sep 22, 2015 03:18 PM
cmsmith
Sep 14, 2015 09:09 PM
NewsBot
Sep 14, 2015 02:02 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
Slayer
Aug 17, 2015 03:55 PM
