12 bolts lube: 75w90 or 80w90
Old Jun 4, 2007 | 07:08 AM
always faster's Avatar
What i wanna know if there is a big difference in these 2 grade of gear oil:
-75w90
-80w90
Im changing my lube in my Strange 12 bolts and it came with 75w90.But when i came to the store they only got some 80w90.The guy told me that there where probably a small but minimal difference between the 2 and that it would work perfectly.
So can i use 80w90 instead of 75w90?
Old Jun 4, 2007 | 07:57 AM
GreenDemon's Avatar
I usually say to run what's recommended but honestly there isn't much of a difference. The question is whether it will bother you every day knowing you put in 80-90 instead of the recommended 75-90 . Seems strange, most places have 75-90 around here, although it may be some synthetic blend...
Old Jun 4, 2007 | 08:15 AM
Thats the problem here.They want to sell me the 75w90 but the only got it in synthec formula wich i dont want since its not good for my diff.
Old Jun 5, 2007 | 06:54 AM
So can i put 80w90 safely or not
Old Jun 5, 2007 | 08:33 AM
GreenDemon's Avatar
You should be fine. If you were changing to something a lot different it would be questionable, but 75-90 to 80-90 is like changing your engine oil from 5-30 to 10-30, either one is usually acceptable.
Victor Lamb
Aug 26, 2017 02:52 PM
BLK1997Z28
May 2, 2015 01:26 PM
maybe2fast
Mar 16, 2015 09:45 AM
ddr698
Jan 9, 2015 10:05 AM
