torque arm bolts
Old May 28, 2007 | 08:33 PM
Garcia95's Avatar
torque arm bolts
haw do u remove the bolt that is towards the transmisson. cause it has two one near the differential and the one furthest from it. i tried taking it off but it would hit on the top.
Old May 29, 2007 | 08:00 AM
2000GTP's Avatar
That one was a pain in the butt, I can't remember exactly what I used, but alot of different hand tools later, I think I ended up using an open end wrench.
Old May 29, 2007 | 10:16 AM
irocbsa's Avatar
I use a 12 point open ended wrench to hold the top and a deep well 12 point to remove the bottom nut. You might have to use a jack to angle the rear axle so that the bolt will come out.
Old May 29, 2007 | 11:08 AM
97formulakid's Avatar
get your car high up in the rear and place it on jack stands. put a jack under the actual rear end and lower it until the bolt comes off. I did mine on a lift and it was a lot easier. It was a pain to get that bolt out but eventually it will come out.
Old May 29, 2007 | 01:45 PM
Garcia95's Avatar
yeah well me and my dad lifted the body of the car after it was on the jack stands and then i got under it and and pulled it out it was hard but we got the sucker out. it would have been nice to have a access to a lift.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
canbaufo
May 5, 2015 03:43 PM
Jason Short
Jan 19, 2015 06:34 PM
