Help!!
Old Jun 14, 2007 | 10:23 PM
lt1chevelle's Avatar
Question Help!!
i need to order this part by tomarrow so i can have it by sat! what is the size of the fitting on the back of the power steering pump for a 95 caprice.
Old Jun 14, 2007 | 10:25 PM
mdacton's Avatar
pretty sure it is one with a little o-ring right?
If it is then it is a siginaw fitting.....a A/C specialty shop or hydrolic shop should be able to hook you up
Old Jun 14, 2007 | 10:57 PM
ya the thing is i was looking to get the size becuase iam converting them over to AN fittings
Old Jun 14, 2007 | 10:59 PM
mdacton's Avatar
I don't have a clue on that car but on the older pumps I'm pretty sure they were 16mm and 18mm threads........Good luck, post if you find the correct size or adapter, I am interested in knowing
Old Jun 14, 2007 | 11:07 PM
alright will do so, thanks for the info tho
Old Jun 14, 2007 | 11:10 PM
somthing like this would prolly work you think?
http://store.summitracing.com/partde...5&autoview=sku
or more like this one i think
Old Jun 14, 2007 | 11:15 PM
mdacton's Avatar
the first one looks like what I think you need, But im not familiar with the one you are working on.......I know thats what you need on the older style siginaw pumps that have the res. made onto the pump....
The second one, i'm not sure if it would work unless it has a tapered thread.
