Why does the T56 sound like it has loose marbles in it?
Old Jun 13, 2007 | 09:02 PM
wrd1972's Avatar
My T56 knocks lightly and sounds like it has loose marbles in it. It drives fine and makes no abnormal sounds when the car is moving. Fluid level is good.
What is going on?
Old Jun 14, 2007 | 07:21 AM
95LT1conv's Avatar
let me guess, in neutral with the clutch engaged? mine has always done the same thing and i wondered why also
Old Jun 14, 2007 | 11:17 AM
wrd1972's Avatar
yup
Old Jun 14, 2007 | 01:02 PM
LSWHO's Avatar
That's the reason I bought an auto. I never liked the feel or sound of the 6 speed. I half regret it. But I still like my car to feel like it's 100%.
Old Jun 14, 2007 | 06:17 PM
Rising Phoenix's Avatar
Something's wrong if the 6 speeds you've driven didn't feel 100%.. the ones I've driven certainly did.
Old Jun 14, 2007 | 06:29 PM
JimboManJones's Avatar
Throwout bearing is what makes that noise. Its the nature of the beast.
Old Jun 14, 2007 | 06:34 PM
wrd1972's Avatar
Mine has done this for years and tens of thousands of miles.
Would this be the case if the noise remains when the clutch pedal is fully pressed to the floor?
Old Jun 14, 2007 | 06:36 PM
That marble noise goes away when I press my clutch pedal to the floor.
I don't know what else would be making that noise, the tranny should be quiet if the pedal is to the floor since nothing in the trans should be turning
Old Jun 14, 2007 | 08:06 PM
rpm4lalo's Avatar
Mine does the exact same thing. i have always wondered if it was the throwout bearing?
Old Jun 15, 2007 | 12:00 PM
GreenDemon's Avatar
Bulletin No.: 03-07-29-004C
Neutral Rattle
There are often concerns of rattle while idling in neutral with the clutch engaged. This is related to the changes in angular acceleration described earlier. This is a light rattle, and once again, vehicles with dual mass flywheels will have reduced noise. If the engine is shut off while idling in neutral with the clutch engaged, the sudden stop of the engine will create a rapid change in angular acceleration that even dual mass flywheels can not compensate. Because of the mass of all the components, this will create a noise. This type of noise should not be heard if the clutch is released (pedal pushed to the floor).
I've also heard that the throwout bearing will cause similar noises (without causing any other complaints)...
Old Jun 15, 2007 | 01:35 PM
LSWHO's Avatar
I'm talking about 4 brand new LS1s and multiple Lt1s. It's the tranny, not a problem with the tranny. I just didn't like it.
Old Jun 15, 2007 | 03:14 PM
Jazsun's Avatar
Yeah its pretty annoying, you can also hear it when your taking off right when you fully let the clutch out and start to pull away. Makes a Growl noise. Its normal, I'm on my third t/o and they all do it.
Old Jun 15, 2007 | 03:57 PM
wrd1972's Avatar
So again back to the question, what in the tranny causes this?
Old Jun 15, 2007 | 04:05 PM
Capn Pete's Avatar
Well, the countershaft is ALWAYS spinning, the input shaft and output shaft are directly inline with each other, although separated merely by a bearing (pretty much) and figure you have 6 gears plus reverse (and the reverse intermediate gear) all turning ALL the time (so long as the clutch is engaged - foot off pedal) so I think it's just a lot of moving parts?? Also, the countershaft is in 2 pieces - the 1-4 cluster is one block, and the 5/6/reverse fits into the tail of that on a spline - and some of those parts aren't "tight" together.
That's my $.02 "guess", after having seen mine apart!
Old Jun 16, 2007 | 09:12 AM
Jazsun's Avatar
I got my rebuilt by t56rebuilds and it still does it. But if it does it under load (like maby in 4th at 20mph and give it some gas, you may needa rebuild)
I;m pretty sure the t/o bearing design /clutch fork pull try style is all to blame.
