fastest times on 10 bolt??
Old Jul 2, 2007 | 04:34 PM
sn8ke eatr's Avatar
we all know our rears are garbage for the most part, but out of curiosity,
what are some times you guys are running on either stock or modified factory rears.
Old Jul 2, 2007 | 05:53 PM
wrd1972's Avatar
Some guys have made it into the 11's on the stock 10 bolt, thats the exception and not the rule. Its the ~1.60 60 foot times that kills the 10 bolt.
Old Jul 2, 2007 | 05:57 PM
mdacton's Avatar
I remember a local guy running 10.80's with a 10 bolt and 4.10s think he cut hi 1.5 60' but he did have a 4500 converter so it lessens the blow.....
Old Jul 3, 2007 | 01:16 PM
Z-RATED94's Avatar
So more converter lessons the blow? I'll have to think on that for a while.
Ok, done thinking, I don't get it. Help me out here please.
Old Jul 3, 2007 | 01:29 PM
TobyZ28's Avatar
A looser convert will slip more... so when the drivetrain is loaded instead of exerting the slip on the gears and breaking them, the converter will slip instead
Old Jul 3, 2007 | 01:45 PM
Airbornec507's Avatar
1.58 60' time here and many 1.60 60' times on a summit rear girdled, eaton posi, richmond 3.73 geared 7.5" 10 bolt. Runs great. Sold it after the 1.58 time because I was surprised it made it through it(ran great afterwards though) and am about to order a 12 bolt.
Old Jul 3, 2007 | 07:01 PM
camaro81's Avatar
Mine finally went a few weeks ago after I went from a 75 shot to a 100 shot. I took 5 teeth off the ring gear. It lived thru a bunch of 1.62-1.65 60' times runnin 12.2's though.
Old Jul 4, 2007 | 04:56 PM
OrbitalChris's Avatar
Im in the 11s with the stock 10 bolt and cam only you could definitely hit high 10s but it wont last long
Old Jul 5, 2007 | 12:24 AM
CCCCCYA's Avatar
11.80's here, with 1.8ish 60's (I know, that sucks). Rear is stock with the exception of 3.73's and a T/A girdle.
Dave C.
Old Jul 5, 2007 | 04:20 PM
sn8ke eatr's Avatar
wow thanks for the replys.. seems the 10 bolt is a lil stronger then i thought. looks like ill be using that for a while then. thanks again guys
Old Jul 6, 2007 | 07:37 AM
JoeliusZ28's Avatar
note that all these times are with automatics. if youre ragging on it with a six speed it definitely WONT hold up to times like that.
Old Jul 6, 2007 | 07:43 AM
wrd1972's Avatar
+1, that makes a big difference.
Old Jul 7, 2007 | 01:16 PM
sn8ke eatr's Avatar
haha good call. ill be on street tires and launch easily so hopefully thatll buy me some time.
HectorM52
Jul 30, 2017 11:46 AM
alphaauto
Jan 23, 2015 07:42 AM
thenewkid
Nov 18, 2014 12:57 PM
