- I need a F-body!!!!!!!!
- cold start valve
- Finally selling my RS need to know what to ask for it.
- Big Block in 3rd gen?
- Start Up problem?? please help
- got some new pictures
- MORE PROBLEMS!
- More on my Sunroof expedition......
- hood
- Rear end
- Looking for some dyno2000 info please
- Low Buck - Performance Heads?
- cowl firebird hood
- Stock Drivetrain worries
- Exhaust Man. Gasket blowing like a hooker
- What is required????
- Need help w/ choosing exhaust system
- Anyone else stuck in Utah? I need to some local help!
- 91 Z-28 Opinions
- SMOKE ON COLD START UP ON A 350 TPI
- hmmmmmmmmm
- Engine build up question
- ANyone in alberta?
- What were the engines options for an `86 Z28
- Track bar
- air condition????
- Tuning help, track times fell off..
- Low vacuum due to low LSA????
- Check engine light question....
- Anyone that has bought new fenders please look within
- Floor Pan
- EGR
- AFTERMARKET CATALOGES !!!!!
- about shift kit/trans.
- WOW, crappy track times
- HELP!!!! car won't start!
- END LINK PROBLEM...
- paging: 1FastFormula
- 82 tranny options
- blinker problem
- Broken thermostat bolt stuck in head
- new end links will not fit!?!?
- When I turn the wheel it chokes....
- Noise from Rear of Car
- speedo recalibration
- oil leak cant find it!
- Running rich...
- Dual Exhaust
- Wheel fitment ?
- Need help picking out a 350 crate
- Need to make up 1/2 second, all on motor
- Fan problems
- overheating problem with in town driving
- sub frame connectors
- Automatic Trunk Latch Problem.
- surges
- oil pan = take motor out?
- Whoo Hoo my car is N/A and now it sounds like i got a blower
- need more power
- Clunk Noise from Rear
- Tach needle sticking...what can/should I do?
- check engine light
- rear-end
- Red Button by my fuse box
- Smoke show vids...
- valve adjustment. HELP!!!!
- POSI REAR END
- Factory Black Lug Nuts
- header pipes
- Sunroof Tech......Gimme your thoughts
- rear wheelhouse panels
- 350 blocks
- Custom, CNC machined, billet Alum strut mounts available
- Need help fast!!
- Fuel smell
- how rare are 85 Irocs with the 305 HO (l69)???
- Quick gears question
- Close Ratio Steering Box???
- disk break locking up warning
- P295/50R15 on 15x10 rims
- cool fuel ????
- Brake problem?? or is it normal??
- DO I NEED A CUSTOM CHIP CAUSE OF MY MODS?
- HELP !!!!
- differance between 9 and 10 bolt
- 700r4.com Tranny Arrives :)
- Starting problems...
- Which Rocker Arms for Stock?
- 92RS 305/TBI What to do for performance
- antifreeze in floorboard...possible causes?
- Need color advice - red IROC codes and shades
- 86 T/A $3500?
- Need help with shock?
- how to overcome? (kinda long)
- I'm having a problem with my car
- Gearing WIth T-56 Tranny IN 3rd Gen car?????
- Rear Compartment Cargo Cover
- rear brake rotors
- new cam f*#*ed up my idle
- need some parts
- Need Better Brakes
- Who has best bang for the buck performance chip?
- 25th Aniversary Specs
- this seems odd
- Will 4th gen wheels fit 92 RS???
- I need some interior parts!
- Need 3rd Gen Help?? Buying soon!!
- Wish me Luck, LT1 cam goes in tomorrow~!
- 84 camaro
- 4th Gen Seats in a 3rd Gen?
- smashed
- LT1 Radiator ?
- Power handling question
- Boyd Coddington Timeless-2's.......
- anyone here use the G2 twisted wedge heads?
- fuel inj. cleaner
- Gas in Oil, Is my Pan Gasket Dead?
- is a 91 Firebird V6 worth $3500
- tranny leak..
- vapor lock???
- STROKER question
- Clunking noise
- Anyone who has had their chip reprogrammed...
- Please HELP! Distributor won't go back in correctly...
- LS1 transplant
- LT1 cams
- Just Broke my Fuel Line to the Filter....
- Header Primaries
- clutch hydrualics.......
- Used engines
- A Big Resource Needed!!!
- Budget TPI combo....
- New gears, now car runs funny?
- Whaddya guys think of this engine combo?
- anyone using or used a digital 6??
- how to put back door spring
- supercharger????????
- Distributor Brace Bolt Size?
- Rocker arms
- HeLp...???
- Rear brake on fire
- WHERE TO GET CLEAN TA????
- Is there a Pontiac equivelant to the IROC or Z28?????
- injectors size? or options?
- Help! Where is the build sheet on an 86 Pontiac TA?
- TBI Buildup!!!!
- Smoke from Tailpipe......PLEASE HELP??
- Dynomax Super Turbo Exhaust system
- How important is vacuum advance off carb?
- Can someone tell me........
- Was '89 the year of the Turbo 6 banger??
- Crack and Pop at High RPM's.
- 4 Banger Trouble Shooting help needed !!
- quick question about a flywheel please help fast
- drive shaft????
- FIPK in a 3rd. gen T/A ?
- EGR Intake, what are the holes on the head side for?
- WTF?! Why the overheating!!
- New Car
- Im going to b doing valve seals, is there anything else i should do while im at it?
- transmission leak while car is sitting 3 weeks
- How to determine tranny?
- What does this mean ??
- Is my Cam causing my Problem?
- brake noise
- 96 exhaust on 84 Z28
- Shake, rattle, and roll
- I'm a dumba**
- L98 and manual tranny
- 5 speed L98 ?!!
- The worst thing I have ever seen......
- Cold Air or Runners???
- Is a 1986 Camaro any good?
- Starter issues...please help!
- Can you resize a rod with the piston still attached??
- TBI 305, 10:1 CR, Vortec Roller Cam.....will it work?
- LT1 In a 3rd. gen T/A ?
- Need Advice on Rear End
- Do I need a new fuel pump?
- sound coming from tranny when downshifting to 1st...anybody?!?!
- motor swap on a 86 IROC any help would be great!!
- i got a few questions.....
- Wiring with an 83 z28
- dripping from inside engine!!!!!!!!
- Doing a non-SMOG TPI Buildup for my better half's car!!
- 87 Iroc value
- Finally started to tear down the 305... some pictures
- Third Gen. Parts on Long Island
- Hiya, I have a question ^_^
- 3 questions
- 2.8 to 3800
- anyone using an MSD 6AL?
- I want an LT1 in my V6 3rd gen! What do I need ?
- Are these good prices?
- T-5 tranny swap, igor look in here plz
- is it a nine bolt or ten
- Brake Booster Question
- Living with a stick at 17
- jumpy fuel pressure
- How Low Can It Go? (Weight)
- hows this?
- 80psi on my oil pressure, help!
- milage when bought?
- To Much Fuel Pressure?
- Speed sensor question ( 90-92 700r4 )
- SLP Prom
- How do I tighten the slack in my steering box?
- 3:73 gears right for me?
- IROC vs. Z28
- 84' L69 swap into 88' V6 bird
- idle problems.
- Problem..... Damn TPI pain in the F'n A$$.
- What is this noise coming from timing cover...............
- 1/4 times
- Timing Chain or ?
- which mod should i do 1st intake or exshust
- Clutch replacement
- $hit! didi i set the timing properly....DOH!!!!!
- HELP!!! What should i set the timing at on a 91z 305tpi?????
- Cam swap?????
- Slow TBI
- Cut-Off Exhaust
- Estimated HP and ET
- MY Z IS MISSING
- T/A motor swap
- wheels???????????
- Help w/ tourqe convertors
- CAI???
- Do trucks have the same style fuel pump?
- BBk afpr for sale $50
- 91z 5spd, is it possible to override the speed limiter?
- head gasket???
- LS1, LS6 swap into a 3rd gen..
- What a difference!!!
- air cleaners
- runners.......
- Stupid little ?
- help! TPIS afpr on a 91z 305tpi, what is best pressure?
- Upgrading to Roller Cam, what timing chain do I need plus cam button?
- tpi wire harnesses
- anyone using an exterior pump
- My Camaro
- Spedometer
- how many interested in ram air hood
- Need help FAST!!! Ignition cylinder replacement
- Fiberglass Hoods
- Hey irocbob89.....Hows the swap going.
- BMW bolt pattern fits on F-Bodies?
- vortec heads??????????
- Where to send 6AL to have it repaired....
