- Electrical problem...please help!
- 5 speed manual trans
- Subframe Connectors
- Not my original rearend!!!
- 5.7L 1/4 mile times
- Starter is Dead
- tpi setups mass air vs speed density
- Which lobe seperation has most vaccum?
- Best way to make 91 rearend into posi?
- what about wheel sizes?
- anyone seen or have corvette seats?
- Does abyone make an aftermarket AC flange for headers?
- Vacuum Hose for Air Conditioner/Heater Selector???
- a while back I asked if anyone would buy a hoodscoop got pics now
- gutting emisions?
- LT1 Rear Disk Brakes on 88 Iroc
- cam selection for 383 Superram TPI
- 4th gen seats
- fuel injection question?
- Extra BBK Adj fuel pres reg
- 700r4 compatibilty question
- What size Belt when deleting Smog Pump on 91 TPI?
- Connecting FAN to ECM
- Wiper fluid wont come out!
- do 3rd gens have frames
- How Long
- Will a Long tail th350 bolt up to a 83z28?
- Starting problems
- 3.42 gear installation help plz
- What about these mods
- 3grand to spend...
- Opinions on a mod while I have my engine out
- Pics Needed!!!!!! Those With Roll Cages Please Help
- Went back to the thirdgen!NO heater though....Little help?
- starting problems
- intake backfire at 5,500?????
- Starting Problems
- Question for "aziroc"
- 87-92 camaro interior
- Whens everyone takin their camaros out???
- Rim Question
- Low End vs High End
- 4 into 1 or tri-y's?
- Water pump
- Steering Wheel
- Still getting code 43 after replacing ESC module
- 342 gear rear end question
- tire to speedo?
- Car having troubles sitting in idle....
- Buying a chip..
- Which Type of Camaro To buy....?
- B&M Console Megashifter.
- Best place to buy carpet!
- tranny cooler
- Very Seriously contemplating LG4 to L98(ish) swap... What do I need? Legal In CA???
- Need some info on muffler choices....
- Pyrometer...how's it used?
- hooker supercomp headers
- vette brakes& probducts sport tuned suspension
- Compression Ratio question
- oil cooler
- 91 RS what to expect?
- elect cooling fan
- Code 32 with gutted cat and cutout?
- Autometer A/F guage question....
- Car won't start b/c transmission.
- Where would I run the wires from battery in the trunk?
- GM Restoration Packet
- white gauges for $20.00
- TBI->carb swap....tach problems
- Why?!?
- 1987' speaker dimensions?
- Main cap girdles for 400 sbc
- Combinations for a 350
- People With long tube headers in here
- cooling fan relay on '92 RS?
- Whats the difference between stock or forged pistons and Hyperutectic?
- 400 Sbc
- Help me tune my PCM for performance
- Where Can I Find Seat Material?
- need help on 350 buildup
- are lt4 springs a direct drop in on l98 heads
- Front Cone IROC question
- Rear speaker access?
- bright lights
- Core shift? Explain plz
- 87 Camaro stalls while idling cold
- heads and cam
- Wiring up Reverse Lights for T56 and more wiring ???
- how to determine my offset?
- 305 stroker and other q's
- t56 transmission.. need input
- Zepher or anyone who put 4th gen door panels in their 3rd gen come in.
- My SSBC 1 LE setup came in.
- Motion Iroc
- carb question
- 405 hp possible?
- LT4 Cam Question
- clearance
- rims, what are your thoughts?
- tranny swap
- 87 Iroc-z
- Will plexi t-tops from an 92 firebird fit my 86 camaro?
- vibration
- Squeeky Brakes
- Stupid Stupid Axles
- 91 Camaro Z28 tranny swap
- mustang guy thinking about getting a camaro... convince me!
- Side moulding on my 79
- backfiring and tach bouncing help!
- Wheres the ground wire at for MAF burn-off relay?
- the worth of subframe connectors??
- Spark Plug Change
- is a 455 outa the question?
- coil over shocks or lower control arms
- opinion on this custom 350?
- shift problem
- The Theory....
- Help: Coolant Leak in engine!. Help!
- 350 Buildup Need Some Help
- Tired of losing, need cheap speed please!!!
- How to check VATS, clutch switch, and ignition switch???
- Help w/mods
- braking noises
- Who's Running Glass Fenders????
- driveshaft
- Can't get u-joints off driveshaft, Any suggestions?
- Comp. Eng. SFC's
- dead rs
- Weird vibration/noise
- Springs and Struts Question
- blow by
- Stronger 700R4, new rear, drivetrain?
- 305 compression?
- 305 power?
- Will 4th gen cat-back work on 3rd gens? B&B Triflow
- Mufflers
- 3rd gen T-top cost?
- horn and cigarette lighter not working..fuse?
- SES codes and questions. HELP!
- Starter Problems
- On my world class tranny I have a short throw hurst shifter,set the shiftstop ?
- dropping 4k into my maro, need advice
- Hey I haven't posted in here for quite a while...
- INFL REST???
- best bang for your buck...? what are the differences in the models
- wheel suggestions??
- Guages
- problem w/eibach pro-kit
- exhaust
- Car says choke, but still runs....
- Is this true?
- Need Help with water pump removal
- Electrical problem or bad battery gage?
- 3rd Gen Concepts
- 86+ Owners
- Metalic scraping noise.....
- how many servos are there in the 700R4 tranny?
- Looking at at car, what to look for? And some questions.
- Transmission Temp.
- tire weight??
- Is it hard to change brake pads?
- autometer gauges
- Mod Tips
- Need a pic of a yellow camaro to paint my car
- new cam in 1991 305 RS
- weird problem with a surprising remedy
- engine combo
- Suspension Question
- what rear end do i have
- old lifters,new cam?????
- What plug wires for cars with headers?
- TBI to TPI and a few other Q's
- ugrading 700r4 transmission plz look, i need opinions
- Australian 9 bolts
- Net and Gross HP
- LB9 TPS Help
- Rear end messed up
- gauges
- please help asap whats this worth
- Whats it worth?
- Moving the battery to the trunk?
- stock 2.73s to 3.42s or 3.73s
- induction
- A/c, Wtf?
- 30,000!!!
- how much hp (stock) on a 89 formula, 305 MFI (dual cats)
- race
- Lt1 Cat Back
- Posi rebuild
- Borla catback for my roc?
- 350? or is it a 305!?
- What are the symptoms of a throw rod?
- rear end help for my car
- need a cam too!!
- Who here has SLP loudmouth in their F body?
- 91 RS 350... power?
- Im hearing noises.
- What do you think I can get for my 3rd Gen?
- I got a new front nose but...
- I can't do a burnout...
- A.P.E. - 3rd Gen Performance
- Iroc Stripes
- Drop spindles?
- Car won't pass smog!
- 2 simple 3rd gen ?'s
- LT1 3rd Genners !!!
- Clutch Slave cylinders
- Battery very dead wtf
- need help please!
- real talk
- taking out tpi wiring
- Bad problems at idle......(please help)
- Now a Firebird owner + questions
- I've decided to take the plunge guys!
- oil guague problems
- A4 guys HELP!
- Anyone ever use GM Top Engine Cleaner on a TBI?
- vortec cast heads and vortec tbi manifold
- Headers or Cats
- PBR rear disc?
- Idle's for a long time
- Does BMR make subframe connectors?
- start problems
- Rim Trouble
- What tire size is equivalent to:
- Water Pump Is it Worth the Effort?
- installing miniram
- Will the rearend from Caprice with 9C1 police package fit my 3rd gen?
- Need a Cam!!!!!
- putting fog lights in 1991 rs
- Hole In My Dash???
- What's involved in swapping out a 10 bolt drum rear and in a 9 bolt disc??
- 88 camaro gear ratio?
- T56 conversion
- where is the fuse for the fogs?
- Where does this PLUG GO?!?!?!?!
- Has anyone ever used Accels cam on their TPI?
- Stealth Ram or LT1 intake?
- 87 Trans Am Brakes, easiest ever
- A GM nightmare
- Using a TPI (L98 maybe) to make a custom Squarebore EFI
- cam
- What about this cam for a 305?
- Reading DTC codes
- Brake/Rear defrost problem
- 305 to 350 swap- Can I keep it smog legal???
- 86 LG4, a few questions for you guys...
- looking for 12sec combos keeping the efi
- dash problems
