Finally started to tear down the 305... some pictures
Old Jun 23, 2002 | 02:59 AM
Chuck!'s Avatar
Post Finally started to tear down the 305... some pictures
Finally. Its just about ready to be pulled after two days of work. The coolant lines from the heater core were the largest PITA thus far.
http://homepages.udayton.edu/~kulcha...2/nointake.jpg
http://homepages.udayton.edu/~kulcha.../nointake2.jpg
http://homepages.udayton.edu/~kulcha...omanifolds.jpg
The largest thing I've done before this was an alternator, and I jumped in this alone, lol. Talk about a learning expirence.
Chuck Kulchar
1991 Camaro RS LO3 A4
15.823 @ 85.84 MPH
Project sLO3
Old Jun 23, 2002 | 03:06 AM
RedIrocZ-28's Avatar
Post
Chuck, Remember there are 2 Ground connections attached to the back of the cylinder heads. There is one on each side. Also, you should take your accessory brackets off before you pull the motor out. Its not that hard, a few nuts and about 6 or 7 bolts if I remember correctly. It will help because you will have more space to pull the motor forward without hitting the "frame."
Looks good man, My motor looked much worse... The lifter valley was caked with burned, hard oil chunks all the way up to the bottoms of the cylinder heads.
Old Jun 23, 2002 | 03:18 AM
Chuck!'s Avatar
Post
The water pump, smog pump, and ac pump thing are gonna come off tomorrow. After that its just a few loose wires and the tranny.
I gotta figure out what the hell Im gonna do with the AC. I was going to keep it, but I busted off that freakin connector that goes on the top of the pump thingy. I was pissed. Maybe I can epoxy (sp?) it and it'll still work.
I was happy to see that it was as clean as it was under the valve covers. Everything looked great, but Im not sure if maybe the heads had been off it before. Did we get rubber valve cover gaskets from the factory? The ones I pulled off are nice enough to be used again.
My knuckles are yelling at me though
Old Jun 23, 2002 | 08:27 AM
firechicken_3's Avatar
Post
be prepared to dent the top back corner of the power steering pump to be able to get that side bracket off. gm just had to put a bolt there and thats what we had to do to my buddies blazer with a 4.3v6, and it appears to be the same brackets
Pics of the Firebird
84' Firebird, 305ci lg4, 700R4, 288/292 duration .450/.460 lift,Edelbrock Performer intake, Holley 600cfm 4 barrel, K&N filter, Pacesetter Headers, 3'single exhuast, dual out muffler, no cat,Motive 3.73's and Auburn Posi
1/4mile 15.17sec @ 92.5mph
84 firebird, motorless and trannyless at the moment (was 4cyl 5spd)
parts car/race car, (at least it will be eventually)
Old Jun 23, 2002 | 08:59 AM
AutoRoc's Avatar
Red face
Good stuff, Chuck! I was going to hint that if you want to put it back together, take a lot of pictures while its coming apart Yu got that covered so i'll shut up. Keep on wrenchin!
Denny Villemure
1989 Camaro IROC-Z Convertible, 305 TPI, 2.73 Gear, Flowmaster 2 chamber. 15.60 on motor, 14.20 on a 75 shot from NX. Woo hoo!
www.denny.cz28.com
Sergio
Jan 27, 2016 04:27 PM
Jazsun
Dec 29, 2014 12:14 PM
ChrisFrez
Dec 7, 2014 06:01 PM
