PDA
View Full Version : 3rd Gen / L98 Engine Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 [47] 48 49
  1. Painting My Car
  2. B&M shifter problem on Auto
  3. Will platinum plugs burn out faster????
  4. 4th Gen rear into my 3rd Gen????
  5. I was wondering if I could do this....
  6. Where can I get a good set of 3.73 gears for a 1989 Turbo TA?
  7. Resetting the computer.
  8. converting from 305 TBI to 350 TPI ???
  9. 90 RS Automatic, what transmission ?
  10. Complete t-top roof conversion for sale
  11. code 32 and 33
  12. T5 leaking
  13. What are these connectors/wires?
  14. 84 Z roller BBC/t400
  15. Couple questions
  16. Sweet 3rd Gen....Never seen this color anywhere else.
  17. BeCool Radiators
  18. tbi differences
  19. Please help! 88 TBI will not stay running in the morning, runs fine in the afternoon
  20. Alston Subframe Connectors
  21. fixed first problem on to the second
  22. Holy Codes Batman!
  23. TPI won't start at operating temp!! PLEASE HELP!!
  24. EGR on Vette Heads
  25. anyone who has swapped lt1 how to do AC compressor
  26. Carb Vs. TPI
  27. Replacement hood louvers?
  28. Are Accel plugs and wires junk?
  29. cracked exhaust manifold
  30. automatic swap
  31. looking for Iroc-Z with the 5.7 Liter
  32. SIRS
  33. Manifold bolts How do you get them LOOSE?
  34. Cooling Problem....HELP
  35. What type of injection?
  36. Exhaust System Conflicts Question
  37. 400/would you buy this hoodscoop?
  38. Why is my gas milage so poor???
  39. Please help, im confounded.
  40. MAF
  41. Torque Arm HELP!!!
  42. ?? FRONT STRUTS ??? KYB GR2
  43. Underdrive Pulley ???s
  44. Need to buy plugs and wires, any recommendations?
  45. I think my cat may be clogged
  46. Cam suggestions with SR
  47. from tpi to carb
  48. fuel injecton wiring harness
  49. Timing marks??
  50. Which ignition should I get for N20?
  51. Valve seals have been changed and now a wierd noise
  52. Belt slinging problem...?
  53. Factory tach is readin wrong in my 91 rs, what to do?
  54. instrument panel light problem
  55. Anyone know where i can find a new rear spoiler for my 1988 GTA?
  56. Boring a 350
  57. NEW JERSEY MEMBERS I NEED HELP
  58. Well it is not the fuel pump.......
  59. '84 Z28 running hot...I think
  60. Third Gen. v6 compressor question
  61. Help with parts
  62. electric hatch question?
  63. Popping sound when making a sharp U turn, what could it be?
  64. Hypertech Cool fan switches??
  65. car won't start, help!
  66. Headlight Gremlin
  67. Coolant Temp Gauge
  68. Fuel injector equation.....................?
  69. What to do if 58mm throttle body
  70. How will this sound ?
  71. Any luck with junkyards ??
  72. hud
  73. GUYS I NEED HELP ASAP.........
  74. Transmission choice
  75. Why will a LS1 alum. drive shaft not fit my car????
  76. Racing with an Automatic!!
  77. Anyone from Calgary Alberta CANADA
  78. Quick Help me before I buy it. TBI Question
  79. ZZ4 in my 86 Z28??? Will this work? All input inside!
  80. Why does his car sound better than mine?
  81. New Gears
  82. Question on removing thermostat on 305 TPI
  83. Run nitrous, or increase compression?
  84. Could anyone guess what problem this is?
  85. Starter
  86. Help inside, '87 Iroc Z wtih 350 TPI, what are best mods for it?
  87. What to look for?
  88. best place to buy l98 long block
  89. Any way to lower idler arm?
  90. Fuel Pump ARRRGH!!!
  91. SLP CAI, i have a question
  92. White faced gages?
  93. Tuner Port Injection:extra parts i have
  94. Different 305 to 350 question
  95. 91-92 taillight question on -87 T/A
  96. Where should I go from here?
  97. bad exhaust sound....help!
  98. Some questions ^_^
  99. stroker for L98 for LT1??
  100. NEUTRAL SAFTEY SWITCH AND REVERSE LIGHT WIRES
  101. 383 in 87 ?
  102. 92 Camaro 5.7L EGR pic PLEASE????.
  103. 1 bolt will not go in my header!!!!!!!
  104. heads
  105. Spring Rate?
  106. PROM help in MINNESOTA
  107. 4.10 gears in an auto?
  108. rear end swap....4th to 3rd gen
  109. LT1 vs. TPI Airfoil?
  110. recomendations/driveability questions cc306 and cc503 cams
  111. cutting out @ 1/4 throttle and low rpm
  112. How to modify 12 bolt to fit Camaro?
  113. Headers and Exhaust
  114. How restricting is the stock throttle body on a 305 TPI?
  115. subs and box for 3rd gen fs
  116. TCI Aluminum Pan
  117. LT1 or what?
  118. Fanning the Flames
  119. Fuel line fittings + adapters ?!?!?!
  120. 3rd Gen Gathering
  121. want to put 4th gen rims on my 3rd gen help please
  122. My paint is finally done!!!!
  123. tires
  124. Differentiating between 700r4, th400 and th350?
  125. help with passenger side header-89 IROC
  126. subframe connectors
  127. Lubed your... HEADLIGHT DIMMER SWITCH lately ?!?
  128. Does porting and polishing help?
  129. 2002 35th Anniversary Camaro SS Wheels
  130. Any Suggestion?
  131. 86 Z
  132. Will this 350 replace my 305 Carbed? 86 Z28
  133. How much 134A in a '85 Camaro?
  134. I have a question about my 3rd Gen GTA
  135. t5 hurst shifter stops :
  136. Carbed 305 to Carbed 350
  137. 3RD. GEN. IGNITION
  138. My 2.8 runs hot & blew a rad hose :(
  139. engine ID
  140. 2 1/2 or 4" third gens cowl hoods
  141. V8 Conversion
  142. Steve10358 or anyone else who can help I have a question...
  143. thirdgen.org???
  144. nos want to know
  145. 2.8 t0 350 swap
  146. O.K. no LT1 cam, what cams are you running.
  147. Distributor problems
  148. Where is the computer located on a 1988 Trans Am?
  149. tranny compatible?
  150. How do you test a distributer?
  151. Where 2 Buy Spark Plug Wires for 3rd Gen??
  152. Block heater stuck in block, what now???
  153. HELP! Intake and Runners.................
  154. Burned Valve?
  155. Harness Bar
  156. Alternates toTPIS Mini-Ram???
  157. Want to buy a 1988 Trans Am GTA with a 305...Have a question
  158. Distributer shot?
  159. 350 implant
  160. where to get sway bar bushings??
  161. How many miles before it's too much?
  162. 2.8L problems...
  163. Which shifter should I get?
  164. Question for you guys...
  165. Nitrous Results inside!! (long)
  166. chips?
  167. Crickets On The Clutch Pedal?
  168. Drilling into the intake manifold
  169. AFPR vacuum line!!!
  170. MASS AIR FLO SENSOR
  171. I Need a Fuel Injector Clip
  172. Torque Arm Placement ON FORD 9 INCH???
  173. iroc mod
  174. pistons
  175. Need Help: all u 3rd gen. proud owners..
  176. 350 Fan Switch in 305
  177. where to buy auto cut outs?
  178. Questions about 350..
  179. Subframe conectors ??
  180. how much horsepower ????
  181. flowmaster or hooker?
  182. Gears?
  183. Tuning fuel pressure from O2 readings?
  184. Found a hood.... rare?
  185. ? 4,500 rpms max without SES light on
  186. auto cut outs????????
  187. Anyone have any suggestions for Torque arms?
  188. pistons
  189. straight pipes.......YUCK plz read
  190. Rough idle
  191. wire fanatics
  192. Subframes...
  193. 90 RS - Source for wheel center caps ??
  194. can some of you guys, take a look at this for me
  195. coil springs
  196. Testing new sig.
  197. Drivetrain issues
  198. Tranny mount?
  199. Suspension: What would u do?
  200. HELP --Crankshaft frozen???
  201. Suspension
  202. looking for performance
  203. Rattle In Dash
  204. TIMING WTF?
  205. T-56 trans into 3rd gen can only handle 450 Ft. LBS TOrque??? I Need more
  206. Air conditioner(can't spell) question
  207. BRakes Pulling HArd RIght! SCary **** Guys HElp *
  208. Replacing PCV and hoses...
  209. Motor Mounts
  210. Electronic Spark Control
  211. Shift Kit
  212. Rear wheel backspacing?
  213. Clutch pedals
  214. what to get factory or aftermarket strutmount plate
  215. Anyone ever put a LT1 cam in your L98?
  216. what mods for putting big block in a third gen?
  217. 4th Gen SLP Loudmouth
  218. Stupid question but I need an answer !
  219. Need some Help
  220. amps drop car doesnt run!
  221. I've modded the hell out of my 305TPI, Any suggestions or helpful hints?
  222. 1982 Twin Turbo Camaros
  223. 383 charger to firebird???
  224. Smallblock 400? Cost? What do you think of my planned set up?
  225. I THINK ITS THE ECM!
  226. How much HP?
  227. Can a Carbed 84 305 H.O be a 14 sec ride
  228. Building Sub-frame connectors
  229. B&M convertor F/S
  230. MAF to MAP?
  231. 305 to 350 swap!!! What do I need to change/adjust???
  232. Speed Limiter??? How can I get rid of it?>??
  233. starter????
  234. Opinions on this crate?
  235. rearend tech.
  236. Someone tell me this swaybar can be fixed...
  237. stock exhaust measurements?
  238. ALL PROBLEM SOLVERS PLEASE READ
  239. How to tell it is a 4 bolt main?
  240. Gutting my Cat?
  241. flamethrower????????
  242. Traction Problems
  243. Tranny and clutch issues
  244. for sale
  245. head comparison
  246. who makes front lower control arms for 3rd gens?
  247. 2.5 radiator
  248. black smoke?
  249. A few thirdgen questions...............
  250. continued problems with temp.
