Upgrading to Roller Cam, what timing chain do I need plus cam button?
Old Jun 18, 2002 | 09:39 PM
IgorT.455/406's Avatar
Post Upgrading to Roller Cam, what timing chain do I need plus cam button?
Hey guys, I have a new style 1 pc. RMS 350 Chevy that is currently running a flat tappet cam. I am upgrading to solid roller and am wondering do I need to use the stock cam button (or cam bracket, whatever that thing with two bolts up front is called that is used to hold a roller in place) and what timing chain do I need to buy? I have a true double roller chain for my flat tappet cam, but I take it that will not work. Thanks guys.
1981 Olds Delta 88 455/th400/3.23 posi
1988 Trans Am WS6, 355/T5/3.27 posi; RPM heads and Intake; Crane Fireball cam; Holley 750 carb; soon Comp RXE294H; th350 & 10" converter.
1994 Trans Am LT1/T56, no cat; Hooker CB; Hotch. SFC and STB; Ripper shifter; Poly mount; Lakewood LCA; K&N FIPK; Hypertech Airfoil; soon to port&polish MAF; Sprint springs & Bilstein shocks; GM Motive 4.10; Hypertech PowerTuner III
Old Jun 19, 2002 | 01:56 AM
RedIrocZ-28's Avatar
Post
Well, I have an '89 350 hydraulic roller motor. It came with the car Anyway, I used the true double roller timing chain and the factory plate that bolts over the cam on the front of the motor. (The one held in by 2 small screws/bolts.) Thats my experience, though I was not working with a solid roller, so I can't tell you for certain if there is anything extra you need.
Old Jun 19, 2002 | 04:18 PM
1989gta's Avatar
Post
you should just need to get a cam and lifters then make sure your valves clear the pistons. my bro converted to solid on his 94 camero it was pretty simple
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
GigaMp3z
Feb 20, 2003 02:57 PM
