- Is a 700R4 Tranny able to work with a 350 HO engine???
- Emissions. Dun Dun Dun.
- tpi/ to blower carb?
- Air Pump question
- TBI v. TPI
- Strange Problem with my re-built 350TPI
- Couple questions
- 86Z shifter assembly to 89 IROC???
- another underdrive pulley question
- what are your opinions on B F GOODRICH COMP G-FORCE TA KDWS TIRES???????????????????
- What Happens @ 100,000 Miles?
- carburetor adjustment?
- Spring install help
- Tire Questions?
- Need Favor: PICs of TBI engine
- Help me build.
- Does the ZZ4 have a forged crank?
- For Sale: 1984 Custom Camaro
- Head Gasket?
- Rear end and brake conversion question?
- Serious Transmission Questions, Help!!!
- headers/ypipe/exhuast?
- L98 idles at 1500 in park......
- LS-1 rear brake swap
- Polish wheels on my RS?
- She's alive!!
- Iroc-Z wheels
- Port/Polish TB?
- Steering play/looseness
- A/C doesn't work! help!
- K&N open air element
- 90 Iroc Mis At Idile
- what size tranny cooler do I get??
- what flywheel does it have?
- L98 dies in the morning....
- TPI pcv question...
- stock heads
- stealth ram pics
- 91-92 ground effects
- Grinding (metal on metal) during turning?
- I need a 3rd gen rear end.
- So what is next?
- anyone need an airbag?
- Computer Chip key
- Suspension
- WIPERS: what's busted?
- starter or solenoid?
- battery relocation/ground effects problem HELP!
- trans cooler install
- turbo
- 91 Z28 intake gaskets
- Wheels and Tire Issue
- transmission
- tpi
- carb
- tpi
- SLP Intake Runners & Poor Performance
- wierd accleration at highspeeds
- Seat Brackets
- anyone put 4th gen carpet in a 3rd gen?
- First Gear Kick-down and turn signal question...
- What heads are available for the TBI?
- Where do I buy a 1984 5.0 H.O. Dual snorkel air cleaner?
- 400 sbc strength?
- my seats?!?!?
- What car is this?
- AFPR ?s
- Single-best mod to a third gen
- Perfect 3rd Gen?
- T-Handle FINALLY came in!
- Thinking about heads for 305
- high amounts of hydrocarbons
- Hood Louvers lifting at high speed
- starter question
- A Very Rare Trans Am!!!!
- What all do I need to stick a lt1 cam in my car?
- Engine Light
- looking to dump ac and air pump
- HOW TO INSTALL A TACH on TPI (87)
- How do I adjust timing with a Vacuum advance HEI?
- EGR help!!
- Hedman Shorty Headers - Do they drop right in?
- How much heavyer are power seats compaired to standard
- power hatch
- need wiring diagram
- Offset for third gen wheels.
- Air cleaner?
- Mint 1le
- C5 seats in a 3rd gen?
- How do I lower a third gen?
- Quick TBI questions
- model?
- 91' and 70' model blocks the same??
- afpr
- Gonna put my motor back together tonight. Which intake do you use?
- Belt on A/C Pump Going
- car won't start???
- How do I beat a 94-98 Mustang GT in my TBI?
- just wondering about hp
- please answer quick question on 700r4 rebuild
- website address for pro-built (new)
- Air cleaner/assembly question
- Will this distributor work?
- TPI conversation to an LT1
- TPI Kickdown cable???
- Leaking Coolant. But from where?
- 350 swap questions!
- Weak shifts on 700R4 with shift kit
- Strange fuse found, what is it
- Runing hot
- underdive pully set
- 2 questions
- New Transmission
- 3rd gen HP ability?
- Wiring harness questions.
- What are the measurements on a T-Top bag???
- Owner of GM 350 HO looking for Miniram answers
- best replacement for a factory t5 tranny
- mini-ram/stealth ram
- figureing it all out
- basic 3rd gen advice
- Holley Throttle Body
- Energy Suspension stuff
- does anyone know if?
- Tornado
- Who does the best.........
- Anyone know of a good site that shows how to port an intake manifold?
- Idle is very high
- code 54........
- 2.8 v6 to 5.7 v8 TPI (1988)
- How to dissable a power antena
- Free 305 long block Dallas area
- Speedometer Problem
- Removing weight, need help
- wheel adapters?
- looking for pics of mods
- Question abot PCV 88+
- Hooker shorties / need a y-pipe, any suggestions?
- body parts
- Electric/Wiring Experts needed, weird ACC fuse problem
- i need a tuneup
- Synthetic Mobile 1.......
- 383 stoker or Lt1
- Bypassing heater core
- K and N drop in,s
- Tps
- B&M shifter problem...
- Third gen really worth it?
- RPO Codes
- t-5
- putting a/c back in and need help
- Energy Problem HELP!
- My tranny makes a grinding noise...
- slp cold air
- Turn signal question...
- Tell me if this TV Cable is broken or if it sounds like Im doing something wrong?
- dyno sheet
- engine power
- transmission problems
- Need something...
- Need help with an exhaust setup
- Subframe Connectors
- long tube headers
- 305 > 454 swap?
- Get The Noobie!!
- Miss from nowhere
- lt1 cam swap
- stall converter
- Lockup torque convertor doesn't lock up anymore?? What gives?
- weird voltage stuff
- nightmare spark plugs
- rear suggestions
- swapping rear ends
- Automatic Transmission Shifting Problem
- Building up my GTA - Ford 9" advice
- Possible to fry MSD box by jumping battery??
- whats tha best kind of Headers to get?
- Fuel Starvation
- weird knocking sound?
- LT1 intake swap
- zr1 wheels?
- 3.8 turbo question
- 383-1piece rear seal, Lenco, in Triump?
- A/C
- b&m shift kit
- driveshaft question
- Does anyone need a new front sway bar?
- When is it time to go bowtie?
- extra leg room
- My speedometer.....
- Will My Tranny Work?
- Need help installing Mallory Fuel Pressure Regulator.
- 400 conversion
- Need Some Help
- timming out of whack
- camaro ground effects
- Tire Question
- 84 Z28 Torque Arm Bushing Mount
- Apexi S-afc
- Idle
- Gas tank Capacity
- close to overheat with advanced timing
- help with a brake unit problem
- TH350 install?
- Carb Problems - help!
- 383
- Transmission Mount
- f/s tpi setup
- M5 to M6. What all do I need?
- in the driveway...
- Where can I find a louver?
- Intake Question
- The Tornado Fuel Saver?
- Rear Defrost Question...
- Can a cast iron like a engine block be welded?
- What pulleys/belts to use
- What gears to get in 6-speed?
- Supercharged 305
- Bumping Noise
- Which springs for drag racing?
- Remove oil pressure sensor??
- Gears
- TH400 Transmission
- hidden leaks....help please
- Overheat after new pump, radiator AND hypertech switch...:(
- kmember
- k-member
- lt1
- tpi?????????/
- Ticking and Vibrating
- 2.8 gettin the boot,305 going in
- F/S TPI Vortec baseplate
- A 6 swap to an 8
- Hood Louvers for an 86 Z28
- Can this Happen?
- Spoiler mounted brake light
- I hate to ask this kind of question.... but
- '88 Firebird 2.8L/173CI -> 305/350 help
- tpi
- transmission
- some upsetting news...need help
- Ok, I need some help again....
- need help on codes for block
- 91 rs
- Megashifter Install
- RPM's fluctuate on start up
- Quick Air Injection / Header Q
- 3rd Gen Project
- Need a trouble code decoded.....
- 6 speed shift plate....
