Fan problems
Old Jul 6, 2002 | 10:50 AM
htrd69's Avatar
Post Fan problems
When using the paper clip trick to do diagnoses, should both fans come on or just the drivers side? I am having a problem with my 87 GTA heating up when setting for a while. I was setting the IAC the other day and when I looked, only the one fan was running. I checked the fan, it works when power is supplied to it. I checked the voltage of the plug-in and it was only .01.
I am thinking of wiring it up to a toggle switch or straight to the drivers side so they both come on together. Which one comes on first?
69 RS Camaro (383,700R-4,12-bolt w/4.11s)
79 WS6 Trans Am (406SBC,factory 4-spd,3.23 posi)
87 GTA Pace Car Clone (350TPI,700r4,140k miles)
97 Bonneville SSE 40th Anniv. (3800 V-6, Power Everything, The little woman's car)
Check out my cars and the For Sale Page at Rods Rides
Old Jul 7, 2002 | 11:25 AM
Randy92Z's Avatar
Post
I just did this mod to my car yesterday. Ive got a 92 Z28 so our relay wire colors may be different, but here goes. I took the A/C out of my car so my aux. fan (pass. side)was not comming on at all and I would overheat in traffic. So I tied the grounds together for both the primary fan realy and aux. fan relay. Mine were located on the firewall on the drivers side. I have three relays there the one on the far left (drivers perspective) is the primary fan relay and your looking for a green wire with a white trace. The middle relay is the Fuel pump relay and the far right relay is the aux. fan relay and you looking for a gray wire. All you have to do is tie the 2 wires together (Green and gray) and the fans will both come on when you car gets up to temp. Thats what I did and it works flawlessly. I even traced the wires back into the wireing harness so I could "hide" the splice. Unless you pull the wireing harness apart you'd never know what I did. Hope that helps.
Convertible W/L98, Mini-ram, ZZ9 cam, TPIS 52mm TB, Comp Cams 1.52/1.6 steel roler rockers, Trick flow 23* heads, K&N's with chopped airboxes, Edelbrock ceramic TES, Flowmaster cat-back, Dynomax high flow converter, Accel 300+ ignition, Fastchips custom chip, Taylor pro 409 wires, March underdrive pulleys, MAC subframe connectors, Lakewood LCA & Adj. panhard rod, SLP 2500 stall, 3.42 rear gear, 90 Corvette rims, White face gagues, and NOS!
[This message has been edited by Randy92Z (edited July 07, 2002).]
Old Jul 7, 2002 | 11:41 AM
panterachik00's Avatar
Post
have you tried replacing the fan relay switch? that solved my problem of my fan not turning its easy to hook up and its only a 10 dollar part. that switch is notorious for going bad in camaros & firebirds.
85 camaro Z-28, fuel injection, V8, 61,000 orig miles
Magenta_Hearts
Mar 29, 2017 08:54 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
mspennyhughes
Mar 1, 2015 03:50 PM
MattFick
Feb 15, 2015 10:16 PM
slothgrant
Aug 22, 2002 03:01 PM
