How to determine tranny?
Old Jun 24, 2002 | 06:25 PM
CaysE's Avatar
Question How to determine tranny?
Where do I look to find out what transmission I have?
1984 Camaro Coupe LG4 V8 (5.0L 305ci)
  • K&N Filtercharger
No more stock!
Old Jun 24, 2002 | 11:18 PM
phoenix916's Avatar
Post
If it's auto 3 spd it's 200r4, If its auto 4 spd its a 700r4. Manual 5 spd is t5 and for spd should be borg warner. I believe that is it for stock trannys unless some one change them should be factory numbers on the side you can probably trace.
Old Jun 25, 2002 | 12:17 AM
Stephen 87 IROC's Avatar
Post
The 1984 LG4 will either be a 700R4 automatic or T5 standard.
Stephen's racing page
or check out the race car
87 IROC SuperPro race car
461 big block
Best ET on a time slip: 11.589
Best MPH on a time slip: 115.91
Best corrected ET: 11.114
Altitude corrected rear wheel HP: 457
Best 60 foot: 1.646
Member of the Calgary Drag Racing Association
Old Jun 27, 2002 | 12:49 AM
82az28's Avatar
Post
if you dont know whether or not the tranny is stock...look at the pan and use this page..its very helpful in identifying.
http://www.nastyz28.com/transid.html
Andy in AZ
Old Jun 27, 2002 | 07:43 AM
Jim85IROC's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by phoenix916:
If it's auto 3 spd it's 200r4, If its auto 4 spd its a 700r4. Manual 5 spd is t5 and for spd should be borg warner. I believe that is it for stock trannys unless some one change them should be factory numbers on the side you can probably trace.</font>
The 200R4 is a 4 speed, and the only time it ever got put into a thirdgen was with the TTA in 89.
The IROC Homepage
View the Restoration of an 85 IROC
Weekend projects aren't.
Old Jul 3, 2002 | 10:01 PM
86 redbird's Avatar
Post
[/B][/QUOTE] It was a monte tranny wasn't it?
Old Jul 3, 2002 | 11:46 PM
Post
The early third gens 82-83 had the TH200 or sometimes called the 200c, 3 speed.
The 200-4R (proper designation) was used in a few G-bodies. Buick Grand Nationals also used them. It has a much better gear ratio than the 700R4.
Old Mar 2, 2003 | 12:02 PM
AndrewC's Avatar
Tranny guide
This chart on transmission pans for identification is not acurate. Take a look at it. The one thats is said to be a THM350 or turbo 350 is a 200c which is the stock tranny in my car. Unless the THM350 and 200c have the same pan, since the 200c is not shown. Does some one have a more acurate site with pictures for this info?
Old Mar 2, 2003 | 02:58 PM
TheGreatJ's Avatar
The TH350 pan and the 200c pan have a very similar shape. the TH350 is a tougher and more commen tranny, and many people confuse the 2 because they just go by pan shape.
Old Mar 2, 2003 | 04:28 PM
AndrewC's Avatar
sh*t its hooped
After taking my pan down to the local auto parts store I have found it is a TH200 "VSM" not a THM350. I've been playing with the TV cable and stuff to no avail. I think my tranny is hooped. It takes 5 seconds to kick into drive and it will not launch right away, almost like a clutch that slips. Driving 1 - 2 - D seems to work ok but altamitely it is still slipping and it isn't low on fluid cause i just changed it and put in a new filter. Dang I hate cars.
Old Mar 3, 2003 | 07:04 PM
TheGreatJ's Avatar
That's gonna be either clutches going out or a front pump which isn't pumping enough. Either way it's rebuild time.
Old Mar 3, 2003 | 07:20 PM
AndrewC's Avatar
I think so too
So I ordered a TH350 swap kit and picked up a TH350 today. I got kinda lucky and got a 1800-2200 stall convertor with it for $100.00 . Ill find out tommorrow how that works. Yeah its almost over, as long as this tranny is ok, i'll be smokin the tires by Wednesday. Ohh, and i can smoke the tires, he he.
I need to find out more about rear end swaps now. Any ideas are great. My best friend wants to build a Ford 9" for me and weld it into the factory suspension, with shortened axles so I can tub it and put big fatties on it. I'm also interested in what my options are for bolt in, factory replacements.
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
drt
Sep 27, 2015 04:39 PM
z28newbie
Sep 9, 2015 10:26 AM
