- Questions about my power curve...
- engine idles high
- Which Sounds better?
- full body kit
- Jacking up engine to remove oil pan?
- Need Info
- fuel delivery problems
- 3rd generation rear end
- Wonder Bar?????????????
- Help with distributer!!!!!!!
- Shakes
- How much of a differance would stock l98 heads make on my car?
- Amber front parking lights ?
- trannys
- Which suspension package is better "WS6" or "Iroc" ?
- tanny I know it has been asked
- exhaust
- Need help with Oil Pump Installation
- In the search for low 6's, Any suggestions?
- heater core
- Whats your favorite Mods ???
- TPI gurus in here please!
- Looking for a good water pump
- Best place to get GM weatherstripping????
- Third Gen tire sizes that will work ??
- Trying to Find owner of this car!!!
- Which clucth to go with??????????
- NEED HELP! 89 TBI won't run!
- ATTN: Those running the Heddman headers and y-pipe from Jegs...
- building a sbc
- diff?
- dual snorkal
- Trying to figure out what this connector is?
- Very quick question please answer
- Anyone know tricks to keep T-Tops from leaking?
- Tranny Idea. Anyone with a built engine in a third gen look
- Power falling off at upper rpms...
- Th200-4R into a '88 T/A, need help bad!!!
- Car wont start when hot!!! Need help!
- ZZ4 Cam
- 92 RS-Brights and Dash lights not Operating
- torque convertor in a BB?
- I need help!!!
- How to wire battery in rear well.....
- whats factory runnin temp on a 84 Z28
- lt1 in 3rd gen
- 383 fuel pressure and timing
- know a good set of gears?
- Can someone give me a pic or a 3rd gen with true dual exhaust
- Need pics of a tubular k member in the car.
- 4th gen engine crossmember in a 3rd gen?
- 383 stroker
- For Sale? How do I figure a good asking price?
- Look at this Iroc!!
- timing(chain,gears)
- Which trailing arms are best for the $$
- V6 to V8 Swap info
- Is there a difference in fenders between 82-90 & 91-92?
- 87 gta trans am
- '91 camaro conversion
- is this camshaft too big/small?
- Hello from Las Vegas
- tank Fuel lines (??)
- 3rd gen conversion
- Best plave to get new headlight motor?
- Need help finding a dash pad
- 305 in a 2000 S10. Where to get motor mounts?
- Need Help Beating A Car!! Please HELP!
- Q about fuelpressure
- Now What?need Help Very Very Fast.
- What's the best Torque Converter?
- This TPI is pissing me off
- Whats a "spreadport exhaust" ?
- What is the best rear-end out there >?
- wahoo it started!
- Ls6.....
- Please help with my 86 Z28....
- Gr0undFx
- Fabricating T-Tops to my camaro
- Thinking or dropping TPI and going to carburetion.
- Pics of 350 HO Crate
- First trip to Houston Raceway Park
- column replacement
- Please check this out
- How much engine oil?
- No Z28?! To Will, and others
- best 383 stroke rebuild kit?
- switch form electric fuel pump to mechanical
- Whining Fuel Pump!is That A Bad Thing?
- external fuel pump...
- Do you have to run fuel into the cabin to have a gauge?
- 305 TPI to LT1, what parts can I reuse?
- 350 Block identification
- rebuild
- Opinions please... 86 IROC & 92 RS
- T56 In 1991 Rs W/ 383
- Kid at Christmas!!!!
- For anyone whos pollished there own wheels.
- fuel pump relay, and getting power?
- Automatic hatchback n radio n such
- bad fuel pump? and q's about it.
- Transmission Leak
- Question for those of you with ram air. . . .
- Weld in sub frame connectors?
- what tranny is this? 4sp
- Nitto's on my 10 bolt?
- good sites? for rebuilt engines?
- need input 350tpi in 92 rs
- std shift 5 speed
- car uses ALOT of oil
- How to fix wide open throttle
- Best Way to Change Valveseals
- Tranny cross member
- wiring a toggle switch for the fan
- tpi witha high idle
- Is there an easy way to check fuel lines?
- Need Shifter Handle, Swapping Tremec TKO into Third Gen
- Computer Problems
- difference between a 5.0 tpi and a 5.0 tbi?
- 383 stroker
- Lt1 in 87 iroc...does it work?
- Anyone using the Fastburn heads?
- is a 305 a 5.0 ?
- Disc-brakes
- How to get Motor Mounts OFF!!!! AHHH!!!!
- Dropped RPMs
- motor pulled
- cast iron heads
- new 350 block 4.00 bore
- Super ram/mini-ram/or port match intake,plenum,runners?
- Will '99 S-10 Gears work in my '87 Camaro?
- SDPC vortech base manifold.....
- witch heads to buy
- timing for 92 305 TPI
- Need some info.....GM Crate Swap
- 1988 GTA trans-am
- headers and exhaust for 87 camaro?
- what transmission is behind a 82 6 cylinder??
- car cuts out
- anyone using msd billit distributor in here plz...
- Are after market manifolds worth it?
- 87 gta trans am
- idle problem
- Extra Capacity Tranny Pan, Worth It?
- T-5 To Richmond Super T10 swap. Need different drive shaft?
- the right combo?
- where to find out which gears in 9bolt
- can I swap from hydro clutch to non hydro
- Not a 3rd gen but a Chevy
- Bigger tb then a 58mm
- fuel pressure regulators for TPI
- Sanderson Headers
- need some opinions - step in here
- Everyone who Has put a t-56 or t-5 in a 3rd gen look inside
- camshaft
- best headers
- Header clearance?
- WOT shift RPM for fastchip????
- Need article from March '95 Hot Rod Magazine
- water pump
- HElP SES light
- What rear end do I have?
- how much hp?
- Driveshaft
- What cars or trucks came with 4 bolt 350's?
- cam swap?
- bearings
- power window switch
- forged vs hypereutectic pistons
- Any one know ther stuff on a later model ford?
- piston size
- what's a good chip for a 305?
- Someone talk some sense into me before I put a match in my gas tank.
- another 3rd Gen for me:D...
- How much does a 87 IROC hood go for?
- I smell gas.
- Why did 3rd gens have so many motor choices?
- What is the Lobe Seperation on an '89 L98 Cam???
- LT1 TB on a TPI???
- GM 350 HO Crate....Which cam to use????
- possibly putting my 406 in a convertable
- stroker
- crankshaft
- est. 1/4 mile times
- front turn signals not blinking
- radiator cap?does it affect runnin temp????
- What Casting Numbers for L98 Heads?
- Can I change to an out of tank Fuel Pump?
- HOw can I change my Fuel Pump?
- 91 z28 305 to 350
- Gauge Install
- My injectors are not firing
- How many CC's are these Heads?
- engine rebuild
- hatch wont lock
- how expensive to make a 700r4 handle 500-600hp?
- runners and port job.....
- Pulls left badly when brakes are applied...HELP
- Has anyone beefed up a T-5?
- LT1 Stroker TT into 85 T/A
- 91 z advice
- Can't shift into Reverse, Help
- so how do I get a BBC into a 3rd gen?
- Will LS1 rear brakes fit on my 84Z....
- ran a 14.4 at E-town with my 305
- T56
- LS1 swap in 92 Z28
- 89 engine cleaning
- Idle
- Would a Dual Fan set-up from a 97 V-6 fit my 86 IROC
- possible cause of shifting problems?
- Best Prices on Gears
- I gotta get up and fix tommorow so I really need advice plz help!!!
- Seat Questions
- HELP! Where to go WIRES/PLUGS for my 84 ta?? anyone?/
- Idle
- Such a thing as hardtops ?
- car running hot?
- top speed
- New Engine
- How can I raise my HP?
- Why New Spark Controller w/ZZ4 Conversion?
- How Much Compression in a Stock '90's 350?
- ideas on engine mouts
- info on a engine swap
- 91 Z28 Question
- Really stupid question
- Which size headers ?
- Rough IDLE Question
- What Cam for a Stock '92 350??
- window motor question
- thinking about pissing off the wife
- Looking For gta wheels
- adjusting my rear koni yellows...
- Knock Sensor gone crazy. PLEASE HELP
- Project: slo3 finished pictures...
- tach?
- 400 sbc buildup option
- Check my list for T56 swap!
- publications and sponsorship?
- Panhard Bar or Trackbar?????
- 1986 z28
- New here
- SOMONE PUT ME IN THE 14's
- Anyone know about rearends?
- rear disc brake swap????
- recomendations
- LCA/Panhard Install
- New to this: What is a good year model?
