- 383, HSR, cc306 cam, and Brodix or Dart heads?
- What could I expect
- 1/8 Scale IROC-Z Model on Ebay!
- 1982 Exhaust Hanger--Need your advice
- timing an 89 350tpi
- How to pick an LB9 cam?
- For Sale 91 Camaro RS
- HELP! crack between header + AIR tubes
- aftermarket intake for 87 l98 no stealth ram?
- roller rockers in 87 tpi different pushrods?
- What is the correct redline for a 1988 Iroc 305TPI???
- Aftermarket Carbs
- 90 5.0 Header Help! Pass side hit A/C Box
- Is it possible to maintain emissions when installing an LT1?
- 98-02 LCS's and Panhard bar?
- 89 305 TPI swap questions
- Dyno of an HSR 305
- What engine do i have?
- Stock Fuel Pump
- Need a chip burnt for my car
- EGR Parts
- best exhaust?
- Lt1 T56 Swap for 3rd Gen???!:eek:
- Best place to get........
- Smog Pump Application...
- Rims
- Correct idle?
- Vin number help..
- To carb or not to carb....
- Main bearings shot, crank scored......options?
- Y pipe question??
- Building for torque for pickup
- l98 cam
- Motor
- What camshaft are you running in your speed density setup?
- Engine Gurus needed, WTF does this mean on the pistons???
- Rear Suspension
- L69 Question
- Third gen motor mount question
- my dads friends new car
- what engine
- Just BOMBED Emissions Test
- l98 intake
- Which Motor is this?
- got pics posted
- how close?
- Dual mufflers on 3rd gen
- wiring problems...
- help
- need info on timing and firing orders v8 350 in a 88 firebird/trans am
- Fixing rot on inside of door edges!
- Catalytic Converter
- starting issues
- 1973 350 engine!
- L98 shortblock weight
- gas in pouring out of the oilpan
- 89 RS Camaro Upgrades
- Bipolar Temperatures
- Replacement TBI
- 305 intake swap?
- fan shreaded its bearing... i think
- How can I get rid of my AC pump?
- Choke Light
- 89 IROC-Z fans stopped working!!!!
- 350 heads on a 305HO
- Hey Babbie.. if you are seeing this check it out!
- Intake Upgrades
- aaaahhhhhhhh
- build sheets for 3rd gen?
- Cooling problem
- Reference signal voltage high
- RPM stutter, car shuts off
- Exhaust question
- Can't Find 383 Stroker Flywheel
- manual air/fuel ratio tune
- Timing vs. Octane
- sorry for being late
- i got a code 32
- EGR Removal
- 91 Z28 1LE on Barrett-Jackson Wed
- getting a new car
- Stock cam specs?
- Paxton Supercharged 1989 Tpi Help!!!
- screw 10s 0r 11s,i want 9s
- 84 Trans Am Headers
- 91 Z28 355 1LE---> BAD brakes :(
- looking for a hood
- Engine ready for mods
- New motor
- LT1 Swap
- Wow been a long time
- true dual exhaust
- Does The Fuel Pump Run Constantly
- Strange Vibration...
- Radiator Hoses & Radiator
- Any 10 or 11 sec. 3rd gens, in here PLZ
- TPI going on a 260HP Mercruiser
- Stepnose of flatnose
- whick chip they look the same but cost different??
- High-flow converters
- Some Pics of the Restoration so far
- 88 iroc 350 tpi
- Exhaust/Muffler
- 76cc torquers on a 350. worth it?
- Hatch motor
- injector sizing
- coolent leak
- Throttle Jump
- 350 TPI Headers
- new exsaust
- just some performance questions?
- Cams?
- 400CI in a 1988 Formula
- Need help with a vacuum line..
- A possible crankcase leak
- Difference between SD and MAF ect
- info for a freind
- Yay My 305 Is Running! Thank You Everybody And Thumpinta!
- Barry Grant Speed Demon carbs..
- Anyone use Dart Pro 1 heads?
- Bucking 89 TBI RS
- Ok I need help with my POS starter
- new camaro owner
- Air Cleaner Problem Clearence problem ...
- Overbore Price?
- shedding pounds?
- bad injectors
- plugs on 89 camaro rs 305
- Huge loss of power and High RPM
- Poor idle... still
- 350 Stroker kit install
- Door Panel Conversion
- To Sell or not 2 sell...
- Still working on my 91 RS
- Open Air Filter
- Whats a solid 305 tpi going for these days?
- 3rdGen T-shirt
- GM Performance div. ZZ 383
- Bad ESC Fusible link or Fan link?
- Help with cam specs for my engine...
- rear hatch
- I need a new Timing Chain and cover, have a few questions
- Smog Pump
- Bad Ignition Swithch
- 3-wire o2 sensor part number
- geting rid of the computer
- Miniram II and NEW Trickflows heads possible for sale!!
- My Iroc is catching smoke
- Its Alive!!!!!
- 327 or 350
- L98 to LT1
- ECM Code 36
- Tune up needed.
- Original '84 Z28 w/ L69 is it worth keeping and upgrading?
- ECM Codes decode
- Brake Vacuum Bost And Trans
- My Camaro is teh sux0rs!!1!
- Crank, Fuel, No spark?
- Where can I find Emissions Legal Headers for third gen?
- fire from coil to cap, but not spark plugs
- speed sensor question
- Rear hatch problems, need advice
- 19hp and 59lb of torque with an adjustable fuel pressure regulator???
- Injector question! Will these work as a replacement?
- Might have to sell the Z.. how much do you tink I can get?
- SOMEONE! please help me with picking a full exhaust system!
- RPO codes for 1989
- I Feel Like an Idiot...help lol
- What gears do I have?
- Will 4th gen "salad shooters" fit?
- So whats my rocker arm stud size?
- Shorties or longtubes?
- Newbie here. Need some advice on buying a camaro
- new motor overheated
- Replacing Stem Valve Seals in a 305 engine
- Z28 vs Iroc-z
- Anyone else have an RS that just won't die??
- Upgrading Cam...Computer Ques.
- engine swap question
- 305 Tpi
- How does "Batch Fire" injection work.
- My IROC says 5.7 Tuned Port Injection
- Anyone seen aftermarket annodized fuel rails?
- Looking for aftermarket Thermostat Housing for 87 Vette
- Headers, glasspacks, straight pipes...
- Injector Connector ?
- can any1 get me a pic of this....it would be amazing
- Alright, what the hell is scavenging?
- Trunk leak ??
- What's the best temp for a Thermostat?
- Body question on convert
- rough idle
- 305TPI aluminum L98 heads
- More 3rd Gen questions
- 1990 Cam Specs
- Just wondering
- Let's discuss the 5L
- Help, my car won't start.
- LT1 into a 91 maro HELP
- More Swap Questions: TPI headers for my LT1
- Headers
- Turbonator ???
- 3rd Gen ?
- E85 Fuel
- Engine Swap Help
- camshaft in a 5.0 TBI from a 4gen
- How much is a LB9/700R4 worth?
- starter problem
- Upside down Charcoal canister???
- Caddy motor swap
- help me out PLEASE!!!
- how to step up the power for a 1989 formula 350 but stay reliable
- How's this combo sound?
- What lifters should I use for an 87 L98?
- how to put a 454 into a 88 irocn
- So Third gen's use a Gen 1 engine?
- evil gremlin?
- LT1/T56 Swap: Speedometer, Mechanical or Electronic?
- Crane Cam Gold Rocker Arms
- Camaro Error Light
- Is there anything i shoule clean or check/tighten under dist cap?
- Bellhousing Problem
- Cam Opinions
- What cam to use here
- Wiring harness cross over?
- Alloy Wheel Size Question
- LT1 in 3rd gen....motor mounts used???
- Wet plenum and runners
- 1987 IROC Scoggin Dickey Vortec 360 hp crate engine project
- EGR Question
- lg4
- speedo/inst. lights
- Differences between RS and Z28
- anyone running this cam?
- New Member IROCU2
- 91 RS TBI Riser, what gives!!!
- Installing the LT1. Parts needed.
- Does anyone know what color coil wires are a stock 86 lg4 Z28 replaceing with accel
- TBI->4bbl
- A.I.R. Pump Will Not Spin
- Voltage Regulator
- L98
- 1 3/4" Shorties?
- Trying to locate a pic of 400 oem pioneer flexplate
- Need some measurements...can I even get a 3rd gen in the driveway?
- What would it take?
- Never underestimate the importance of a properly running ignition system
- Headers/Exhaust
- Slightly rough idle
