- battery drain when cranking
- compass in the console?
- 1992 Z28 Convertible5.7 ????
- Hello, every one-
- Wondering which to choose.
- Tune up
- Building a v8 Small block
- new guy wants to know
- anyone try one of those ebay 'swap harnesses'?
- alright, did a motor swap, ran into some probs
- Carb tuning advice for higher elevations?
- the whole story
- 91 Z starter help
- 91 Z starter problems!
- Inexpensive shaft mount rocker setup?
- 87 Camaro dash wiring
- 5 gen interior in a 3 gen camaro???
- 82 crossfire 305--why won't fuel pump run when ignition turned "on"???
- drivetrain value
- slow cranking
- building a 305 h.o
- Windshield Wiper not Clearing Completely
- 153 or 168 tooth flywheel?
- my engine
- charging system
- I Need .....
- serpentine pulley set-up for a Chevy 2 Nova
- 87 iroc 305 tpi -to- 350
- TBI flow
- 350 Crankshaft In A 305
- removing unnecessary wiring and electronics...
- looking for some power
- T-Top center bracket?
- Car stopped afterfiring when I disconect the 4 wire plug that you unhook when seting
- Fuel Pump Bad??
- LT1 swap into '89RS
- Tpi Swap Help Continued
- time for a new clutch...
- Problems with "new" cluster
- Engine Specs
- What happened to My IROC
- Speedo swap
- idiling problems
- How Do I Swap My 85 Ecm With A 88 Ecm
- Got my 3rd 3rd gen today !
- tpi swap help
- project or parts car!
- Question about LT headers
- HELP!!! need advise on my 87 IROC
- 5 speed swap
- Do people stop you and ask to buy your car?
- rear end to tranny brace
- Heated O2 sensor questions
- 89 305 tpi, wount idle
- Moving Back to TX from NY
- 350 swap
- True Dual exhaust
- WHat is the name for the exhaust valve on pass side exhaust? how can I remove it?
- Exhaust Help
- Choppy idle, car runs like garbage
- Whats up everyone?
- Starter fusible link wire, where does it go?
- Nothing Left To Do But Cry
- my 305 needs help!!!
- Putting a 3.9 V8 in a 84 Camaro can it be done? & has it been done?
- wiring help
- Needing to take the whole dash apart..
- Best street/strip clutch?
- '88 IROC Z-28: Several questions
- ground on Aluminum heads?..stupid ?
- How do I fix the holes in my crossfire hood?
- 1992 z28 700R4 to Turbo 350 Swap.
- Anybody runnin 3" duals?
- Have questions about stock or aftermarket wiring
- What makes starter 'slow crank' when warmed up?
- Manual Steering Box needed....
- TPI very hard to start, very bad idle, stalling.
- AFR head and ARP head bolts?
- changing motor mounts
- So...I bought a painless wirirng harness.
- Which Clutch For my 86 IROC?
- 4th gen Rear End Swap - E Brake Cable Needed...
- Will this engine work in my Camaro?
- 383/T56 Launch Picture
- cam question
- Winter storage suggestions?
- LT1 headers in a 3rd gen
- Kado91z clear your PM box.
- New Best @ M11 Event!
- 87 camaro Iroc/ Electronic auto tranny??
- What is the fuel capacity of a third gen?
- 454 in a 86 f-body
- Head studs or head bolts
- thirdgen.org/
- I have on my shelf R43TS R45TS NGKUR4 &rapidfire #2 which should I use?
- Header wrap or spark plug sleeves?
- lt1 easier swap for a 3rd gen
- What size edelbrock y pipe should I use? 2.25 or 3 in? how can I mate it to
- Transmission Crossmenber???
- New Guy Here, opinions/advice wanted.
- Clogged cats?
- I'm Going To Blow Up My Camaro!!
- what's this part?
- 4th gen Rear End Swap...
- 1988 IROC Z28 Basic Help Needed
- LT1 Heads on an old SBC
- 2210's Header gaskets, which ones?
- Hooker Headers Full Length..
- Idle problems
- Long Tubes
- 3rd gen wiring help
- radiator plug below cap
- Custom Exhaust Idea...Opinions? (Pic)
- 86 305 not starting
- possable injector problem
- Super Ram 396 Stroker
- parts site
- Worth?
- New Distributor...non HEI
- cam selection
- Where can I get a door roll pin?
- Starting Problem 90 Iroc
- Re-Gearing the differential???
- problem with my 82 with tpi. help needed
- Stock L98 with only exhaust and 1.6rr dyno numbers ...
- 350- buy retail rebuild, or do it myself??
- LT1 In 3rd Gen swap. Wiring write up.
- Radiator question!!!
- Cam Choice for 305
- Missing and Cutting out at 2000RPM
- Hedman exhaust 68471
- Lt1 wiring help! Lt1 in 91 z28
- 3rd Geners Help me....
- Good Deal or No?
- Idling Rough and Running Rough
- Cam end play?
- oil pan gasket sealing?
- Subframe Connector pics plz
- Dearest third-genners, tis I.. 85_305. I have returned
- 89 rs 305
- RPM, what to shift at
- rebuild prices?
- Gas mileage V6 Vs. V8??
- Power Steering Pump, anyone have this happen?
- RPM's running 1300 HIGH
- Need to know FAST, will this exhaust work??
- 4th Gen Rear End Swap
- Why cant my 1982 Z28 'burn rubber'? (long)
- Biggest noob ever
- Ignition switch woes.
- Running rough
- Fuel pump voltage
- Electrical Problems....
- Distributor off a Tooth?
- Did a camaro come with a 12 bolt from factory
- Heat Shield over muffler... Do I need it?
- 305 to 350 in 88 IROC
- Tranny/Engine help
- Need help asap
- Im making the dive
- looking to buy a 383 longblock for my 86 z28
- Tach reading way too high.
- T56 in 3rd gen?
- one wire alternator question
- Fuel Pump
- Let me know if this exhaust idea will work!!!
- exhaust/headers question
- Where do the rods that run down the column to the ignition switch go?
- Gak! Running to rich, no idea why
- 1990 Camaro question
- TH350 modulator line
- 2 piece timing cover? which one?
- Gaskets for a 3970010 block?
- please read..thanks
- Choke Problem?
- 1984 camaro steering column?
- Metric or Standard bolt?
- Brake Conversion Question
- hatch pull down motor problems.
- VSS Code 24
- 92 305 to 350 swap
- 89 iroc z trans
- Vent Question..........
- stumbles when cold, CANT FIGURE IT OUT!!!
- Are all air dams for 82-92 F-body the same PN?
- need manual tranny options that can handle a 383
- Looking to buy an 83 Z28. Questions.
- Worth Fixing?
- My 89 iroc has a hot starting problem?
- Mini ram vs. Holley stealth ram
- any significant differance between long tubes and shorties?
- stock 350 tpi 1/8 run
- Wide body kit/what do you think??
- Heads cc chamber size???????
- true duals?
- Corvette L98 or a 305 TPI, which do I go with?
- Harmonic balancers effect on engine revs!!!!
- 2nd-3rd gen project car
- HELP WHIT remote mount turbo system IN MY TIRD GEN
- cc306
- 6 or 7 or 8 inch balancer for 383?
- a few questions about my car
- Helping my friend swap a lt1 in his 91 z28
- rough running
- trouble with tpi start
- GTO brakes on a 3RD Gen?????
- can u decode this VIN please!
- HCI recommendations for my setup.
- cranks but does not fire
- Limited slip? or Posi???
- distributor...
- Instrument cluster wiring diagrams
- How to remove Heater diverter box?
- T56 swappers!
- Does anyone have True Dual Exhaust on thier 3rd gen?
- question about t.p.i
- v6 to v8 swap
- need a balancer for my 383 which one? FLUIDAMPR?
- alittle confused...
- help figuring this out
- Duel fans question
- Hesitation problem
- trouble with TPI and painless
- Cam choices for my stealthram'd 383
- Horsepower decals
- 350 tbi to 305 tpi ?'s
- Roots type for TPI?
- victor efi and stock ecm
- Delay on crank
- What will an IROC be worth in 10 years?
- Car Turns Off??
- AIR Removal
- Lt1 Tb
- 86 TPI Corvette mods..
- Anyone have knowledge of "Comp Cams Extreme Fuel Injected Cams"?
- starter the 350 for the first time...
- Going to 17" wheels Pro's/Con's
- high torque starter motors
- fusible links
- For those with factory radio's
- V6 2.6L(89 RS) to V6 3.0L(90 RS) Engine swap
- what type of speedometer sensor??
- how much nitrous on this engine?
- Car won't start today
- is this a realistic goal?
- Accel or MSD ignition??????
- Gutting the cat?
- fan question
- Spark Plugs????
