- Exhaust
- How far can you run rubber fuel lines on a TBI engine?
- New Cables & Spark Plugs - Slow to Start
- Just bought '86 Z...Any experts on mods?
- 85'IROC Z28 what kind of engine, trans, rear?
- horrible gas mileage
- Anyone have Eibach pro kit???
- 350 HO Crate!!!!!!
- comments?what would some of this cost?
- What exhuast r u running???
- Torque converter lockup
- What do you use for rust removal?
- Will a LG4 electric fuel pump run a TBI motor
- Roller 305 or a Flat Tappet 350??
- 1990-92 camaro recalls
- Buying camaro #3
- Will swapping rear-ends interfere with my speedo/tach???
- Serious Overheating Problem
- 3rd Gen's With 4th Gen Rears Look Within
- What would cause my 88 to climb to 2K RPM?
- TPI tunnin' ?????????????????????
- Please explain how running rich caused knock
- How much of a boost would a new ignition be?
- engine cutting off
- Lighter t-tops? Plastic possibly?
- Starter Questions.
- knocking noise?
- 86 coolant temp switch
- 9" Borg Warner on stock 88 IROC-Z?
- Just bought 88 IROC-Z, 350. Fuel pump Q:
- Trick Flow Heads?
- filling in the wheel wells (17" or 18")?
- 3rd gen tranny swap...
- TBI guys in here please
- IROC pricing and suggestions
- Mini Ram...Whats it worth?
- TPI L98 goes kaputt!!!!
- Rear hatch problems.
- HELP! ? ! ?
- How much of a difference would the K&N filter that bolts onto the TB make?
- No Spark at all???
- anyone have datamaster?
- ZZ4 Cam in a 350 with Comp-Controlled Q-jet??
- Ran the car after the build, numbers are hard to stomach.
- another question please..
- hello everyone...please help..im getting desperate...
- storing 1991 camaro rs for winter
- HELP TRANNY PROBLEMS
- thinking of selling my 6speed
- TBI Injector GM5235279*RPD
- I finally ordered my AFR195's for my SBC385
- Who has a big block in their 82-92 Camaro?
- 92 Camaro Z28
- ball joint replacement
- now that we've established that only vettes had aluminum heads...
- aluminum heads
- rough idle, stalling
- Convertible Firebird
- New Engine Knocking with Timing Set at O degrees!!
- Water Coming from Knock Sensor Hole??
- Am I Being Anal? Catalytic Converter Question
- 3rd Gen HP Fuel Pump Systems
- 350 build up
- What Speedo Gear With 3.42's?
- Might get a 87 Camaro 305 4bbl. Need advice
- What's the factory spring rate for the rear springs?
- Do you know...
- 350 TPI MPG A4 & pricing read this.
- Competition Engineering rool cage???
- I got a small, annoying problem.
- engine swap v6 -> v8 HELP
- How much could i get for my car.
- fog lamps
- 90 RS ground effects - how do they come off ?
- Throttle Body Spacer/Heat Insulator TPI
- budget build ups... what would you do?
- Something has gone wrong!
- Will It Start
- 91-92 Z28
- Window Deacals??
- GTA Floormats?????
- Can you put the LT1 Stock cam into the L98 TPI?
- Timing on a TPI
- Coolant Temp Sensor
- Shift Improver Kits
- Is this a factory flaw?
- My 305tbi RS keeps dieing on me
- old nascar model kits bobby allison esc............
- Engine plans needed
- Electrical Problem...Bad FP?!?
- 1985 Z28
- HELP! Will an set-up on a 1986 TA Edelbrock headers fit an 84 TA?? help!! READ!!
- color change
- Air induction ??
- What rear end ??
- i have a question about with fbody to pick?
- On a 1986 Z28 is the AIR CLEANER the SAME on a COMPUTER controlled Carb as a REGULAR
- Anyone ever try to lower your car and it sits higher???
- engine stalling
- 89 camaro rs with a 305 tbi dies at stop signs
- Would my prom unit be causing my computerized 700-R4 to not shift when I want it to?
- "That damn trim"
- thinking of getting a 3rd gen
- how do i boost up my rs?
- Fan doesn't work, why???
- SFC desing prefrance?
- Considering 3rd gen Formula - Need help
- I need to rebuild my 350 how much would it cost me?
- Interior
- Bodykits
- 3rd gen headliner to 4th gen
- ZZ4 for Early 3rd Gens
- injector connector seal.
- E-Tec 1/4 times(finally)
- Flames from under the hood!!!!!
- how fast am i going?
- fouled plugs AGAIN
- No/Low Oil Pressure ?/
- Cam Button and newer style blocks for roller cams
- Anyone have detailed insructions on taking the dash apart?
- Car Seems Sluggish Lately..
- Anitfreeze is dripping on to my passenger side floor.
- heater hose installation
- W.T.B. frame for convertible top
- What do I need to do to lower the front end of my car about 1/2"?
- Im bad with tire sizes can someone tell me about how big a BF a P295 50 R15 is?
- 87 Z28, Engine dying unable to diagnose
- where to find custom rear decals for the bumper of car
- Rust in Rear is this a bad sign?
- "Turn that $hit down..."
- vortech head question
- I'm published!!!
- I think i messed up my block
- 1982 Berlinetta 305 auto, where to start?
- Where are the RPO codes at?
- Oil Pan R & R
- Anyone out there got a dual fan Set-up for Sale, or tell me the best place to get one
- I just installed dual 12" radiator fans on my car.
- Good Deal?
- NO CLUE whats goin on
- 305 to 350 clutch question
- 180 thermostat does it affect performance?
- jetting question for secondaries
- Were exactly does the TPI sticker go on the back bummper?
- silly question regarding IROC-Z tachs
- I need your help with some ECM Files...community support!!!
- Re-building rear end
- Brakes on my 87 LT1 GTA
- car wont start
- 4:10 gears
- Need Help Choosing Pistons...
- radiator dimensions
- Wheel locks
- Can anyone help me with a plug question?
- Dual Exhaust? PLEASE?!
- Arg... SLP way to much, other headers that are great?
- Ram Air Intake
- cams too big
- What the hell happened????
- Need some part numbers....
- Leather Seats Where to Buy Resources!!!
- 3rd gens w/T-tops how much power do you have
- Bilstein shocks and struts how good are they
- 89 IROC....tell me something about his car
- LT1 Swap: Started it Up for First time today WOOHOO
- How do you pull the pins out of the drivers side harness plug?
- hood louver kit
- cooling system acting crazy
- Open element filter on my TBI ?
- Guaging interest: burn my own chips or ed wright
- something loose/broken in the front end???
- electric fan switch where are you?
- Can someone tell me what may be casusing an overly stiff brake pedal?
- has anyone actually put a 89 TPI, wire harness and computer in a 91 or 92 RS
- Torque Arm?
- I need Head
- What's the best air intake?
- Knock sensor is retarding the $hit out of the timing in my car.
- Nology Wires????
- My car is putting out large amounts of NOX. Will not pass inspection.
- Ok, here are my pics, see if it'll work this time.
- I finally got my pics on here, Tell me what you think.
- throaty muffler for an 84z????????
- How important is it to have KYB 5 ways all the way around?
- O2 sensor questions...
- We should get together a group of 3rd Gens to represent us in the Hot Rod Power Tour
- Front end shake (VERY BAD!!!)
- Anyone have a 383 and pass the sniffer?
- left turn signal not working
- ball joint removal????
- benefits of ram air?
- How can I stay at WOT in 4th gear??
- what should i do now?
- Dumb question.
- Intake manifold question
- Valve cover gaskets
- electrical problem still!
- How much for a rebuild???
- Engine stuttering when cold...please read
- 92 305TBI to 89 350 TPI, what do I do about the speedometer?
- detonation!!!
- Anyone know anything about Air Flow Research (AFR) heads??
- Non t-top 91/92 How much ?
- proper way to hardwire fan?
- Speedo probz...
- fixed my fuel leak but now stalls at abything more than 50% throttle
- Camaro 1985
- swapping an LT1 TB into my superram
- Oil pan fit?????????
- New Interior for my 82'
- 84 Z28 engine fan problems
- Need Help With Smog B.S.
- Anyone here from Pennsylvania?
- Interior
- Performance Upgrades for '89L98
- Spohn TQ arn th400 in a thirdgen
- will a comp cam 305 from an LT1 work in a L98 TPI
- V8 To V6 Swap
- oil leaking 305 tpi 85 Z28
- 84 z28 engine light????????
- What is needed for 95' Z wheels on 90' Formula?
- I need 350 swap help
- A funny noise when I punch it??
- New car is a piece, NEED HELP!
- Who has the best T-top weatherstripping kit?
- 5 speed upper console
- Can I put my 01Z28 shocks and spring on my 92 RS
- question on lifters and rockers
- What should I sell my jet stage 2 chip for?
- Replacement carpet ? Year One vs ACC ?
- automatic to manual?
- How do you descreen a MAF?
- where should i start my modifications?
- What tires to get
- Help, my 'bird is spewing oil badly
- Busted Gas tank
- stripe kits?
- Cast iron manifolds
- MAF?
- What brands available for fan switch?
- RPM gauge
- Free ram-air mod?
- Non Tech: 1/25 1987 IROC-Z Model kit
- reverse valve body tranny's
- Quick quistion
- Please help, car will not run.
- 3rd gen sites??
- My E-Tec dyno numbers (long post)
