Is my Cam causing my Problem?
Old Jun 24, 2002 | 03:16 PM
Odd_Ball_Racing's Avatar
Question Is my Cam causing my Problem?
I have a 383 stroker motor in my '87 Camaro (was an LG-4 with 4bbl.). I am still using the CC Q-jet and all the SMOG equipment. I have around 9.5:1 CR and my cam is a GM 383HT Cam. Its specs are .431/.451", 196/206 dur@0.050", 109 LSA. Everytime I give the car alot of gas I get a check engine light, same thing happens when I have been driving along time and when I lift off the gas I get the same check engine light. Both lights will go off when normal driving starts again. The code I pulled is 32.
I have everything plugged in, could my cam be the problem? I am worried that the cam's 109 LSA is too much. Someone suggested I switch to a ZZ4 cam. I need to pull the motor again anyway because of a broken oil ring. Any help is thanked in advance.
Cable Bright
-'87 Camaro Z28 (gettin' STROKER Power)
-'91 Caprice 9C1
-'70 El Camino 454 RAT
"....after all, people just want a normal life and a cool car....most people settle for the car."
Old Jun 24, 2002 | 05:05 PM
Marc 85Z28's Avatar
Post
That code is for a Barometer sensor fault. Check first to make sure you DO NOT have a vacuum line attached to it.
1985 Z28, Jasper Class 1 350, Edelbrock Performer intake, Dual snorkel air cleaner, K&N filter, Edelbrock headers, Catco cat, Hooker cat-back, built 700r4 w/ Darrell Young 2400 stall TC, Jet stage 2 chip, SSM subframes, Lakewood LCA's, Powertrax locker w/stock 3.23's, Centerline Auto Drag's
Old Jun 24, 2002 | 07:21 PM
Post
Thanks for the reply. I looked it up in my Camaro manual and it says its a differential pressure sensor. Is that the same thing you are talking about?
I have a vaccum line running from a manifold port to the MAP sensor (passenger side). Then I have a another thing that looks almost like a MAP sensor on the driver side. It too has a vacuum line running from it to a port on the back of the carb. The vacuum lines are all routed the way the chart told me to. If there is something I should change, please tell me.
Cable Bright
-'91 Caprice 9C1
PCLZ28
Dec 24, 2015 05:19 PM
dirtybird81
10
Jan 6, 2015 09:31 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
GigaMp3z
Feb 20, 2003 02:57 PM
