$hit! didi i set the timing properly....DOH!!!!!
Old Jun 20, 2002 | 01:08 PM
taner's Avatar
From: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
Exclamation $hit! didi i set the timing properly....DOH!!!!!
when i set the timing on the car, i unplugged the brown/black wire that was hanging off to the pass. side fender well area. checked it at idle, roughly 9/10degrees.
then with wire still unplugged , revved it up to 3000rpm, and it read 35 degrees, is that correct? this is the STOCK HEI distributor, for the 305 tpi in the car.
thanks a bunch!
taner
Old Jun 20, 2002 | 01:11 PM
irocz383's Avatar
Post
Thats pretty advanced... I think the stock 350 is 8 degrees and the 305 is 6 degrees or something like that. I'm probably wrong but I thing thats in the right neighbourhood.
Old Jun 20, 2002 | 02:14 PM
RedIrocZ-28's Avatar
Post
Stock with the wire unplugged should be 6* advanced, taner. and yes it should jump way up when you get on the throttle.
Old Jun 20, 2002 | 07:36 PM
taner's Avatar
Thumbs up
thanks a bunch!!!!! i will let you know what happens. i am off to set it right now!
taner
Old Jun 20, 2002 | 09:10 PM
taner's Avatar
Cool
car runs awesome! pulled almost 4 degrees out of it. bottom end may not be as strong as before but past 3k rpm it is a whole different ball game
F'n1996Z28SS
Aug 23, 2023 11:19 PM
HectorM52
Jul 30, 2017 11:46 AM
cmdeshon
Parts Wanted
Dec 16, 2014 07:58 AM
