- Car has alittle misfire at idle, runs rough at 2,500 rpm what could it be?
- loudmouth on a 85 camaro?
- Whats the best fuel to use for 86 TransAm ??
- Header Cracked, because wrap?
- Installing a hurst 4 speed Indy shifter?
- third gen value?
- 305 tbi - 350 tbi HELP!
- Torque Arm Hitting Floorboard
- Found quite a bit of my problem was in the parts...
- New Timing Chain/Ignition Timing
- Engine ran rough, now missing badly
- Custom Hood Pics..Yay Or Nay?
- Replacing a stud..... how hard is it?
- SEVERE loss in mileage...any Ideas? Please?
- Headers for 91RS
- Is this a crazy 3rd gen idea?
- Looking for wiring Harness Diagram,
- Is the fuel pressure relieved or not?
- 84 Z-28 wiring issues
- Fuel Injector Cleaner's - Recommendations...
- HELP, Burning A Lot Of FUEL!!!
- Drilling out stock holes for new gauges.
- Where can I get a cam for my 89 RS???
- Trick flow heads
- Smoke when started
- Fuel prob, help
- tubular K member
- new problem??????
- Finally got it all together
- Very Rough Idle and Engine Turns Off!! Why??
- Slow speed surge
- Stroker Kits Street legal?
- Need some quick advice on an IROC-Z
- '83 police package camaro?
- New Spohn 3rd gen parts
- tips on pulling an l98 out of a vette
- Engine Number Location on TransAm - Anybody???
- Injector question
- classic third gen stuff
- Need Help,Washed my 5.7 liter and now,
- Can I change the gauge cluster on my 3rd gen?
- Exhaust help
- porting tb?
- Spring Questions
- HELP, bad idle, hesitation
- Full Tune up...what to do?
- Remember how i said i thought my ecm was going south...
- 89 Gta
- Installing the LT1
- A4 to M6 speedo question.
- Hesitation when I first push down on the pedal
- 90 iroc z value?
- Windage Tray in Oil Galley Need To Go Back In?
- 1989 should be the oldest 3rd gen I search for ????
- simple dash question
- Engine block ID Question. 350 or 305?
- So how reliable will a 3rd gen be if I get one in good shape???
- When did 3rd gens get the 6 digit odo?
- no gas? cant start? bad fuel pump?
- Shaking Past 65mph...New Suspesion, Rims & Tires...Puzzled :(
- 305 TPI 5 speed
- Where can I get a stainless steel Bolt set for a TPI set up
- 334 debate and y not continued
- Anyone running a MiniRam setup?
- tank fuel pump delete
- Do any of you guys run a TPIS custom chip?
- Just curious
- Anyone
- Long Spark Plug Wires
- valve guides
- Ok, so I'm confused...question about a 3rd gen I was looking at buying
- 4th gen dash in 3rd gen car?
- K Member + Stock style A Arms
- stealth ram and ram air
- ECM going south?
- Headers installed, now backfiring @ idle and bad gas milage
- Carb Or Tpi?
- Will a v6 alternator work on a v8?
- ZZ4 cam?
- Vortec Vs Center Bolt?
- Door Hinges
- High Shift Point?!
- Crank bolt heli coiled and just a tiny bit slanted
- 383 Tpi
- Starting Problems!!
- Hot Mods?
- Fuel pump
- Stalls when its raining?!
- 4th gen (98+) front brakes on a 3rd gen
- rice eater
- Max valve lift for 350 TBI?
- Reoving chrome from exhaust tips?
- 305 Vs. 350
- best trans for a tpi
- Shifter Problem????????
- Possible ignition problem
- Need sum timing tips asap... bout to spray
- 1 piece vs. 2 piece rear main seal
- intakes
- Who has 383 TPI motors????
- Quick cam ?...
- Cylinder heads - which to get??
- Finally found out what I did to my engine
- Am I screwed or can I do something about this?
- Repalcement Steering box
- I need to port SLP Runners
- need ur guys help
- 88 z 5.ol engine swap ?
- aftermarket parts
- Low buck project
- LT1 guy needs help with buddies TPI setup
- 1984 305ho to 350ho swap question
- Lt-1 swap into 1991 RS
- It's offical, I hate my car
- Camaro Wheelie Movie
- 305 Cam Numbers/Ranges
- LT1 in 87 TA
- T-5 Tranny dilema......
- Derale Adjustable Fan Switch (DAFS) - #16759 - Extra info
- Somebodys got to have an answer for this.......
- Camshaft upgrade.
- lalala
- what to set my timing too
- Thinking about buying a '91 3.1 V6, need some help
- engine swap - bracket problem
- 1992 Cooling Fans Schematics - Help Diagnose Fans Not Turning ON
- Inside Temperature Gauge Post - Rumor or Real??
- Cam Question??
- Anyone here ever seen a comparisson test of aftermarket TPI runners?
- cooling fan
- New Guy + Pictures
- Hooker Competition cat-back
- Confusing Error Codes
- Is the 305 L98 Worth Building??
- Worth it?
- Alternator Replacement????
- What to do with my 1988 Firebird?
- Has anyone swapped an automatic out w/ a T-56?
- LT1/LS1 Intake
- LT1/LS1 Heads
- So....I just bought and LT1/T56...
- Racetronix Wiring Harness Instructions
- Single to dual radiator?
- $1095.34
- Installed New Air Filter
- car will not Idle all of the sudden
- Keyless Entry....
- IS IT BETTER TO RUN HEATER HOSES DIRECTLY TO INTAKE & WATER PUMP?
- Which Is Better: Reverse Or Standard Rotation Water Pump??
- 305 Heads...
- The 305 is dead.........any suggestions on a new engine?
- Computer Programming
- New motor, rough idle- runs better warm than.......
- About to spray! Which plugs?
- 91 camaro roller cam in 92 truck
- Reverse Rotation Verses Standard Rotation Water Pump??
- map sensor
- Spring Install Guide
- new exhaust system
- Can someone help me
- Tune Port Engines
- Wiring experts, help me out!
- lt1/ls1 maf
- these relays...
- Chilton or Haynes
- Shorties or TES
- 1991 - add vortec heads how much cam??
- Ignition Coil
- Need VATS help!!
- question about oil pump gears
- 92 rs tbi no start ... help??
- Electrical or mechanical gauges
- So, what should my ignition coil ohm out to?
- tpi cam Q please help
- Thumbs up to wonderbars!
- how can i lower my ET-1/4 time?
- So is any of this 305 stuff true?
- 1991 camaro fuse box diagram PLEASE CLICK
- Does anyone own the "Jongbloed" hood?
- Trying to hook up an msd 6a???
- Can somebody ID a part for me?
- Stupid head lights
- New Third Gen quarters - Where can I find them?
- 383 Stroker engine vibrations
- 3rd gen f-body and 5grand
- BBK Manifold
- what should I do with old 4 bolt 350 block
- O'crap Broke It Big This Time!?!?! Help
- 89 RS camaro motor swap...
- I'm missing somthin... tpi wont pull hard enough
- Summit Racing - Borla Exhaust...Crazy!!
- transmission install prob, pilot bushing too small?
- Sway Bar questions.
- Alternator Not Charging
- STUPID AUTO ZONE KID!!! needa belt size
- Hedman headers and hedman y pipe question.
- bad fuel pump?
- 1982 Camaro Pace car carb
- A good ammount of CFM for a cooling system?
- Question about L-98 tuning??
- do i need tuning???
- Which is a quieter muffler?
- jumping timing?
- Can someone recommend a good brand of exhaust?
- Only Right Wheel Has Power...
- tbi to carb- how??
- Hi, new to forums.. and possibly future camaro owner
- Which Goodridge brake line model?
- Check out these scantool readings for my MAF. Bad?
- URGENT!!! What's this relay!?!!
- 89 camaro rs TBi 5.0
- Where can I find a 5 wire maf connector??
- code 43
- What temp does Hyp. Thermomaster turn fan on?
- What Oil Dipstick can I use for a '91 Z28 with headers?
- cooling fans won't come on?
- wierd coil on a/c box??
- Fuel line
- Power windows
- tach's shot
- what kind of hp gain can be expected by adding a 400 crank
- converter 700r4/4l60e
- What did you pay to tint back window?
- changing fuel pressure vs mpg
- 420 hp 84 TA
- tired 5.7 in my 90 formula
- FI vs Carb....Horsepower Difference
- max fuel pressure
- one little wire..
- Long tube hooker o2 sensors
- Car shuts off?
- TPI on old block?
- Derale Adjustable Fan Switch Installation Pics
- Great...
- Build my own exhaust?
- 700R4 trans shift cable bracket
- Goodyear hoses
- slp cold air intake
- What track times and numbers should I expect?
- need help with tranny??
- white goo under valve cover
- idle tuning with cc306
- tranny shifting problem
- Changing cam in car
- !smog pump, !ac, stock tensioner.
- Please help, fuel pressure problem??
- car won't start security/brake light
- my friend wants to build a 350. Have some questions.
- 700r4 shifting high
- Fuel system pressure
