Broken thermostat bolt stuck in head
Old Jul 7, 2002 | 03:47 PM
91RSconvertible's Avatar
Red face Broken thermostat bolt stuck in head
anyone have any suggestions on how to get it out? there is about 1/4 - 1/2 inch of the bolt sticking up still...
Old Jul 7, 2002 | 04:52 PM
mrr23's Avatar
Post
when you say thermostat housing bolt stuck in head, you mean in the intake right? anyways, you will need to drill into the bolt. then retap the hole. you may need to get a helicoil kit for it.
fl-thirdgen.org#0004
moderator @ www.fl-thirdgen.org '86 t/a, 3.27, auto, homemade CAI, hypertech AFPR, comp cams 1.52 roller tip rockers, holley prostrip annililator ignition system, shift kit,
OEM corvette 2100 rpm convertor, lakewood adjustable panhard rod and trailing arms, edelbrock 6872 headers, catco 6007 3" cat, flowmaster 17151 3" single outlet catback. 14.91 @ 90.57 177.7rwhp 356.4rwtq
Old Jul 7, 2002 | 09:07 PM
AutoRoc's Avatar
Red face
Drilling and heli-coiling would be alast resort. If you have something to work with use it!! Get some TIGHT vice grips on that thing and turn!! Vice grips rule so damn much it isn't even funny Goodluck!
Denny Villemure
1989 Camaro IROC-Z Convertible, 305 TPI, 2.73 Gear, Flowmaster 2 chamber. 15.60 on motor, 14.20 on a 75 shot from NX. Woo hoo!
www.denny.cz28.com
Old Jul 8, 2002 | 04:08 PM
STAYBG's Avatar
Post
I GOT THE BEST THING OF ALL THAT WONT SLIP, READY? A 6'PIPE WRENCH.GOOD LUCK.WORKS EVERY TIME
1987 IROC-Z28
355 TPI
58MM HOLLEY TB
HOME PORTED PLENUM
LT1 INJECTORS
HEDMAN HEADERS
CRANE AFPR
MSD WIRES
JET FAN SWITCH.
3' 2 chamber flowmaster cat-back system.
STILL TO COME,
3:73 POSI DISK REAR
4' COWL HOOD
4TH GEN INTERIOR
ALL AROUND SUSPENSION KIT
Old Jul 8, 2002 | 05:33 PM
hotrod1984s10's Avatar
Post
I have had a similar problem. Soak the broken bolt with liquid wrench. I used a stud remover, but with only 1/2 inch of bolt remaining I would go with vice grips. First try tightening the bolt slightly, then work it back and forth. When you replace the bolt use anti-seize on the threads of the new bolt.
Roadie
Feb 16, 2015 10:34 AM
rcajun86
Jan 30, 2015 01:56 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
thenewkid
Nov 27, 2014 09:41 AM
