PDA
View Full Version : 3rd Gen / L98 Engine Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 [31] 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49
  1. Trunk no open
  2. Temp. gauge goes to 240!! but doesn't overheat??
  3. 3" exhaust = 3" Y-pipe ???
  4. Code 32 pissing me off
  5. 2.8 to 305 swap ...
  6. unplug alternator?? helps times?
  7. Oil weight
  8. fuel injector identification??
  9. Speedo recalibration
  10. plenum
  11. 4 inch Mufflex
  12. cam basics
  13. How reliable is your third gen?
  14. has anyone heard of this body kit???
  15. 3rd Gen guage cluster swap
  16. Needed PICS of SLP 2OTL
  17. A ??? for all the 3rd gen people
  18. where to find 9 bolt rear axle
  19. Difference between 350 and 305 computer?
  20. Smoking when started
  21. 350 TPI TRACK TIMES?? stock
  22. TBI injector ratings
  23. Harness swap Q's.......
  24. 350+ stroker motor cams
  25. vibrations
  26. Cam install
  27. Significance of a Torque Arm
  28. Harness swap Q's......
  29. Engine Cleaner
  30. Headers?
  31. M.A.F. Connectors.
  32. Auto to T-56
  33. What size swaybar in my '92?
  34. 305's Internally Balanced?
  35. Valve Seals are Toast!
  36. Torque Specs for T56 Install
  37. T-5 Shift Pin?
  38. long start up
  39. More input on poor idle please
  40. BBK throttle body 52mm or 58mm?
  41. A/C removal !! ??
  42. Hookers header..home made y-pipe ??
  43. SGI-5 ??? t-56?
  44. lt1 short block (ebay)
  45. how much hp does it have 205 or 230.
  46. Dart heads and edelbrook manifold
  47. Sick and wrong
  48. Rear End
  49. Using a hammer on your starter?
  50. Which gears are considered "performance"?
  51. Are the runners Aluminum or iron
  52. lowering pros/cons
  53. drivers side door mirror removal and other q's
  54. Tranny scaring me.
  55. how do i install these pulleys
  56. how do I change valve springs? HELP!
  57. drive shaft length
  58. fuel injectors???
  59. EGR Valve
  60. Carb size in 85 5.0?
  61. Do I have a tranny problem?
  62. For those who want a Stealth Ram
  63. shift kit installation?
  64. Brake Lights
  65. Iroc?
  66. T56 into a 1990 350 automatic ???
  67. RPM's in 1st
  68. What Kinda Brakes You Guys Runnnin?
  69. Shift Kit?
  70. what's the h.p/trq. on 91-92 camaros
  71. Need Pics of 91-92 Camaro with Cragar S/S Rims
  72. t56 in a 1990 camaro? will it fit?
  73. 3.73 4.11 ??? t5 t56 ?? which one?
  74. gas gauge problem
  75. LOUD NOISE under the car ... : (
  76. 82-84 f-bod with an AMC 390 and 4spd?
  77. Car not charging properly?
  78. custom guages
  79. Fuel Pressure Regulator
  80. Headlight Dimmer Switch
  81. installing ram air boxes
  82. A few motor questions...Please Help...
  83. Scat vs. Eagle
  84. There is a hole in my exhaust manifold
  85. Darn Hatch Motor!
  86. Part number for charcoal canister
  87. Building up the 305...question about cams
  88. is it possible to use TPI intake on a vortec heads?
  89. Reasons for detonation
  90. tpi wiring harness
  91. Will this exhaust affect my setup? (picīs)
  92. My IROC-Z
  93. Is my hypertech chip the problem??
  94. New heads
  95. inline fuel pumps
  96. window motor
  97. Wow, smell of gas BAD
  98. how much to get 300 rwhp
  99. Y-pipe 350 single 3" cat
  100. speed limiter?
  101. Forced Induction
  102. lowering springs
  103. Auto To T-5 swap
  104. hp/tq # 85 Trans am
  105. air foil install
  106. Has anyone replaced their distributor???
  107. broken bolt rant
  108. Starting problem.
  109. Interelated Problems --> Crappy Preformance help
  110. Hesitates when gas hit really fast
  111. seems like car is running rich
  112. Headlight problem
  113. Transmission problem, what do you think?
  114. Mobil 1 Decal & Stuff
  115. Transmission fluid change
  116. Swapping power steering to manual?
  117. Car Stalling
  118. Car Stalling
  119. a v6 700r4 tq. converter on a v8 700r4?
  120. Difference between...
  121. Loose door handles
  122. What do I need to make an LT1 work for my '88
  123. Motor dies when trying to get right on it....
  124. Engine Temp.
  125. jet pulleys
  126. cross drilled rotor swap
  127. Where can i get the Iroc-z center
  128. Exhaust Suggestions - Muffler Rusted Off
  129. 52mm Holley TPI TB-noise?
  130. LS1 aluminum driveshaft?
  131. is my mechanic on acid?
  132. milled/ported stock throttle body? 48-52mm ??
  133. Holley Stealth Ram and SLP runners
  134. tuned port changed to carburetor ??
  135. super noob questions
  136. Throttle Body Bypass: Brass fitting?
  137. Location of the buzzer?
  138. Help!I cant figure this out....
  139. Distributor?
  140. 7 5/8 disc rear in 86 Iroc
  141. Stealth Ram and 91 Vette???
  142. switching to carb
  143. LT1 Cam question
  144. 383 & TPI? advice needed
  145. RPO codes
  146. Seats from a 4th gen
  147. stock hp/trq ratings for all corvettes 82-92
  148. Anyone who knows TH-350 trannys inside please.
  149. Check Engine Codes
  150. A 9-bolt was given to me!
  151. prop valve question for 4th gen rear
  152. For everyone that's ever experienced code 33......please read
  153. Improve HVAC air flow?
  154. Anyone from Corpus Christi, TX
  155. Intake ID help.
  156. Plentum Porting
  157. Stalling while stopped in drive
  158. Hi-beams
  159. voltage problems
  160. throttle body bypass? resistor chip?
  161. Diff between 89-90-91
  162. HSR going on
  163. idling high??
  164. Power adders for 89 350 TPI
  165. Buddy bought a 1988 White GTA 305 5L
  166. throttle body bypass?? resistor chip??
  167. 4th gen to 3rd gen interior swap?
  168. Intake leak question TPI specific
  169. leak from heater core outlet on radiator
  170. trany?
  171. LCA moutning pic needed
  172. Pulley Queston
  173. 10 second n/a 383 possible?
  174. Automatic shifter plates
  175. can't figure out this overheating problem
  176. difference in 86 and 87 rear ends?
  177. LT4 hotcam kit in L98
  178. My 305 TBI Needs Power!
  179. New Engine: Advice needed
  180. pic wanted
  181. roller rockers
  182. 2.08/1.6'' heads, cam, TH700, gears
  183. twin air filter setup, cut out the bottom of airbox ??
  184. Holley stealth Ram, having installing problems, HELP!!!
  185. Need Help With T-56
  186. cruise control lever
  187. Thinking of dropping this engine in my car...What do you think?
  188. How to find out the gear ratio in your rear end?
  189. 87 GTA L-98350tpi 1/4 mile times.
  190. help with info
  191. Dual intake setups
  192. spark plug reading??
  193. hesitation/miss
  194. Bay Area Dyno Day
  195. ground effects
  196. SLP 2400 Stall Convertor
  197. Intake ID help.
  198. What 60-foots can I expect
  199. 3.08's too low for 6-speed?
  200. Strength of a 10-bolt?
  201. Snake/ Sleepy Eye mod
  202. AIR FOIL tell me everything you know
  203. Plastic hood scoopes still available?
  204. 1988 Camaro Ignition
  205. What is the best year for the 3rd gen?
  206. Parting out 84 Z... Inquire within...
  207. Lt1 parts swap!
  208. any suggestions?
  209. Diff btwn 88/89 5.7 tpi throttle bodies
  210. 1993 nissan 300zx non turbo
  211. How to polish plenum and runners
  212. LT1 intake on a LB9
  213. how to tell if i have a 350 or 305??
  214. TPI Swap
  215. can I run 1LE a/c delete pulley if I have no smog pump on bracket??? Anyone know???
  216. Fastest ThirdGens?
  217. Rear defogger doesn't work
  218. True duals possible on Z28?
  219. What belt size???
  220. Blinker conked out
  221. Adjustable panhard bar?
  222. I can't keep coolant in the xpantank
  223. 305/350 solid balancer?
  224. What sequence of events when starting car?
  225. LB9 question.
  226. attempting to start winter beater
  227. Need help with Be Cool radiator!!!
  228. Dynoing my car this weekend
  229. L98's in Vettes
  230. Car wont start
  231. LT1 Cam for my 3rd Gen
  232. LT1 third gen.
  233. Front Sway Bar
  234. it better be
  235. fuel questions
  236. getting car painted,primer body work tips?
  237. thinkin about gettin the holley SR
  238. 1990 Camaro Air Filters/ Intake question
  239. 1990 5.7 ECM computer and Intake questions..
  240. yet another question about 4th gen rears
  241. 3.73gearbehind a L-98 350tpi
  242. Ashtray spring??
  243. 1992 Patrol Car
  244. Air Fuel Ratio Gauge?
  245. I got my car painted.... problems
  246. Can I use LT1 pulleys/brackets on a regular sbc
  247. Do any of those infomercial products work?
  248. Letting motor sit
  249. Hood pop problem
  250. cam swap for L98? LT1 ?LT4 hotcam???
