- smoking
- Spark plug gap
- Changing thremostat- Please help!
- What in the hell?! Battery charging wire
- March Mid Mount Serpentine Setup Info + Pics
- What engine to start with?
- HEI help
- Alternator
- Car wont start.. makes a dry exhaust noise, doens't sound gassy
- Offset/Drop base air cleaner?
- 1986 Computer controled
- need help
- exhaust leak
- firewall ? anybody ?
- question about a complete drivetrain swap on a 91
- 89 wiring help needed
- Myth or real world gains?
- 1986/87 tpi 305
- Skipping TPI350
- HIGH Idle
- 355 AFR HSR Cam Selection
- Engine for '92
- stupid question, spark plugs
- Quick Question
- Heater Valve problems-Help!
- Vortec heads?
- L98 with a manual tranny
- Looking for raspy, nice, exhaust for 92 z28?
- Component Location Manual/Guide
- hatch motor??
- Voltage problems, please help!!!
- fuel pumps
- 87 IROC 350 4bbl or TPI? PLEASE!
- Throttle Body / Water Crossover Sensor......
- Problem with air filter base not clearing distributor
- iroc help
- Looking for headers, what do you recommend?
- 3rd Gen "Choke" light
- free mods
- 305 twin turbo?
- about to buy 88 V6 Camaro
- spark plugs
- Good header back system?
- 350 HO Deluxe Swappers
- Car wont start.. no ignition power....
- 84 Z28 emissions question
- Horn Button Problem
- newbe question kinda
- Just bought an '86 Camaro- What should I do.
- Engine Swaps
- what time would my car run
- Intake/Exhaust
- alternator wires?
- Need Help!!!!!
- Starter Issues / Brake Issues
- just bought 91 rs what mods to do
- power steering hose on 87 iroc
- LT1 in 89 z28
- what type of fuel filters do 'maro's have?
- How do you set roller rockers on a 91 350 tpi car?
- rust f#$@in' sucks
- cam problem
- 350 with 5spds
- TH350 & torque arm problem
- Help with cam
- Peg Leggin it.
- Alarm system.
- Charging problem..
- Please hep w/ the designation of the cylinder numbers...
- 87 IROC 350 to TPI
- Where Is The Vehicle Speed Sensor Buffer On The 89??
- T-56 swap costs?
- Cam for my engine???
- Modding TPI
- dynoed the 305 TBI/N20
- Camaros: hard to handle in rain?
- Damned dual-snorkel intake wont fit!
- Pssing emmissions with a carb
- Camaros SUCK!!!
- ultimate exhaust system
- Need ALOT of help!
- Crank pulley bolts torque specs???
- Performance parts to upgrade ride?
- "BLACK DOG" Camaro
- ls1 motor mounts
- Code 54 back and better than ever.
- Another Torque Thrust II Post...
- IROCZ TPI to 1st Gen SB
- 700R4 plug question
- First Car/Camaro
- Dropping in the new engine.
- ???? totally clueless on this problem
- '89 TPI - no start - can you help?
- My Serpentine belt keeps splitting
- Will a MSD 6A fit
- Flow Master Aftercat Exhaust Can I get it off??
- Changing from Convent Oil to Mobil1
- Rim's question
- 305 tpi on a 350
- 1986 305 TPI running rough, 3 different codes. Ideas?
- Map sensor vac port
- weber clutch/flywheel?
- Steering wheel ?
- Exhaust
- Motor mounts
- L98 heads on a tbi 350
- How rare is this otion package
- Pan hard
- How rare is my car???
- Edelbrock Carb on stock intake
- I need a Y-PIPE for my 3rd gen Z28
- WOO, WOO!! Got antother Z28!
- Will they fit???
- 87 Iroc SB 350 headers
- "VATS"
- Car won't Start ( Serious HELP is Needed
- Which is better? Open element or dual-snorkel?
- Corvette servo
- New spark Plug and wires replacement
- Tranny Rebuild Time?
- Pulling out Tail lights
- ya so i forgot i own a 3rd gen
- Starting problem
- anyone ever have this unusual problem?
- hp mods for 305
- Missing header bolts?
- cooling fan problems
- Distributor Help
- smog junk
- Need help on engine swap
- What year was the camshaft bad in the camaro?
- Cam/Crank shaft Positions
- Trouble Starting
- cant keep the big block cool
- fuel pressure gauges
- Vacuum Lines/Plumbling
- New track times...check-em out!
- Cars made
- engine swap
- Whats the stock gear ratio on a 88 iroc
- tpi motor
- how much hp gain with extractors?
- Fan... and overheating...
- What port size is a '91 stock y-pipe? (Exhaust replacement ideas too!)
- Power Steering Pump Woes
- SLP runners on a 305?
- Any links to a site that lists SBC cylinder heads?
- what does this wire connect to?
- best stock fuel inj??
- Need help.....info about my 160 thermostat
- Brakes?
- Chip for 305TBI to 355TBI... Where do I go?
- It's alive!!!
- Black Dog
- Anyone installed this Borla exhaust before?
- 98 K1500 4l60e trans bolt in for thirdgen?
- EECS ?? What are the options?
- $100 camaro
- TPI - custom chip - EGR
- best low-profile centerbolts?
- Fuel pressure gauge
- Picture time, pics of stuff I dont understand :)
- So besides a 305, What else fits a 700R4 Trans?
- im back, new times, No probs
- 455 pontiac.... 500+ horse?
- Fuel injector installation
- low 13's?
- Can i use this fuel rail?
- How much is a DECENT 89 GTA worth?
- Run on
- Starter for my 87
- Which of these is the best way to go for cat's?
- starts & dies
- Fuel Pump Question
- Power loss problems + Hesitation
- Quick Tranny ?
- header gaskets
- Long Tube Headers And Daul Exhaust
- 30lb injectors on a stock L98
- lack of power/hesitation in my 305 TBI
- rattling noise on 90 rs
- Misfire on cylinders 2 and 5
- RPO Codes
- Engine Hesitation
- Got a Code 32...
- Ls1 T56 In 89 Iroc!!
- knock sencer
- engine swap fuel pressure
- umm...my blower motor is stuck on?
- Installing a stealth ram
- Adjust roller rockers - zero lash
- Could I have a chance against this car?
- Tockico or KYB
- Power Steering?
- Service Engine Soon
- Lt1
- maybe you can help with this
- When you get a code 32.....
- bellhousing bolts
- Help with Replacing the Rochester Carb...
- Lost
- Whats The Best Oil Weight To Use???
- 305 to 350
- What Thermostat?
- Identifying these injectors..
- New Motor Breakin???
- Camaro trouble NEED HELP!!!!
- Camaro Troubles NEED HELP!!!!!
- 80-Z28-350 Stalling When Hot
- What injectors should I get?
- Another TPS question
- Does Anyone think this is strange
- Fuel Pump
- 305 TBI cooling system
- motor mount ?
- Motor ?
- stock engine accessory limits
- Performer Or Torker Which Intake
- Noob to 3rd gen
- torque arm bushing
- tranny for caprice motor
- TPS adjustment question
- How to install hydraulic brake line on Slave Cylinder
- What cam for a 89 RS camaro 5.0 TBI
- Setting the timing broke my MAT sensor?
- How Many Teeth In The T56 Tranny Gear?
- Installing distributor with engine in
- Planning an LT1 swap into my 86 Z28
- fuel Pressure with 5.7 TPI
- Underdrive? Pulley Setup?
- My timing is off apparently
- Problems converting to turbo400
- Electrical Question.
- Strange vs Motive Rear Gears, also which ratio:
- 700R4 build up to go with 300 hp/400 ft lb L98
- 305tbi
- Transmission help!
- Shifting High?
- Am I in too deep?
- CompEngineering Bolt-in SFC C3120*
- Flowtech Headers
- cam help with 400
- 86 350 tpi motor rebuild suggestions
- Question about my car's carpet
- Fuel Injector Installation-
- little help with motor mount
- Which is better, Carb or TPI?
- Gas Tank
- Transmission problems, 1984 Z28, 5 speed, manual?
- 92 305 TBI to TPI swap
