Clunk Noise from Rear
Old Jul 5, 2002 | 12:05 PM
Tom87IROC's Avatar
Unhappy Clunk Noise from Rear
I just noticed a clunk that happens only on quick acceleration. The kind you need to chirp the tires. Under normal accereration there is no noise at all from the rear. I looked under the car but did not see any shocks broken. Any suggestions on what to look for?
Stock 87 IROC 5.7L Factory Bose Stereo, T-tops, 3.27 Borg Posi
Old Jul 5, 2002 | 01:14 PM
aziroc's Avatar
Post
well my 86 iroc did this when i first got the car. when i accelerated quickly or came to a quicker tehn normal stop, there was a cluncking sound from the rear of my car. it ended up being my torque bar *traction bar*. the mount/bushings were bad. but my g/fs 94 firebird started to do the same thing. it was here bushing/mount to her tranny. the torque bar cost me like $100 and $40 labor to put in and the tranny mount cost $50 *polyuritane* and $50 to put in,
1986 IROC-Z
406 SBC TPI
399.6 rwhp 436.1 rwtq
*damn injectors running lean*
Old Jul 5, 2002 | 01:26 PM
BLOWNBIRD's Avatar
Post
Change your trans mount, it sounds like you are getting a lot of pinion angle under hard acceleration, causing the rear u-joint to make niose.
Old Jul 5, 2002 | 01:43 PM
AutoRoc's Avatar
Post
Another vote for the trans mount. Mine recently broke and it was sounding like the rearend was sliding back and forth upon acceleration. A friend guessed the trans mount and i was like.."No way, that makes a hard clunk sound"...Sure enough he was right. Buy a Polyurethane piece from Energy Suspension. It should cost like $20 or $40.
Denny
Old Jul 5, 2002 | 01:59 PM
pcolaIROC's Avatar
Post
well, the worst it could be would be a broken rear-end (hope that's not it )
Old Jul 5, 2002 | 08:23 PM
Tom87IROC's Avatar
Post
Thanks for the info guys. I'll get it to the shop and mention the tranny mount and traction bushings. I find it hard to believe that it is either one of those things. The car has only 61,000 miles and is garaged all winter. It still looks pretty good underneath. But what do I know, that's why I asked you guys. Thanks
Old Jul 10, 2002 | 08:02 PM
fastenuff's Avatar
Post
tranny mounts are nutoriously bad on camaros. Averageing only like 60-100k miles. and the more you beat on it the more often you have to shange them.
Old Jul 11, 2002 | 12:53 AM
firechicken_3's Avatar
Post
i broke like 3 of them when my car was a wimpy 2.8l, in less than 20k miles, over about a 2yr timespan, i think the motor mounts were shot cuz, the v-8 has only broken one, and that one had spent some time with the v-6
Pics of the Firebird
84' Firebird, 305ci lg4, 700R4, 288/292 duration .450/.460 lift,Edelbrock Performer intake, Holley 600cfm 4 barrel, K&N filter, Pacesetter Headers, 3'single exhuast, dual out muffler, no cat,Motive 3.73's and Auburn Posi
1/4mile 15.17sec @ 92.5mph
84 firebird, motorless and trannyless at the moment (was 4cyl 5spd)
parts car/race car, (at least it will be eventually)
Old Jul 12, 2002 | 10:48 PM
Tom87IROC's Avatar
Cool
You guys nailed it again. Just got under the car with a new transmission mount. When I jacked up the tranny, the mount was split in two. The tranny mount only cost $5.41. I'm not complaining, but was that too cheap? My car does have 61,000 miles, so I guess I was due for this. Can I go back to chirping the tires again?
PublicEnemy1
Apr 7, 2015 12:21 PM
BigWil
Mar 29, 2015 12:24 PM
Fatdog2
Feb 12, 2015 12:24 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
squarehead
Nov 21, 2014 08:02 PM
