T/A motor swap
Old Jun 19, 2002 | 10:56 PM
ironjet's Avatar
Post T/A motor swap
my sister has an 86 t/a with the high output 5 liter. the car has 131k on it , the body/int are nice but the motor is just about dead. does anyone know if a 350 out of an 86 c-10 will swap into place of the 305 with no major problems? - thanks
01 arctic white ss m6 79 Z-28 10:1 350 w/ msd hooker super comps 650 dp ssm lift bars 3500 stall & 4.10 auburn gear and factory paint straight from the 70's. no times avail cus' our track sucks
Old Jun 20, 2002 | 12:35 AM
puckboy60's Avatar
Post
my friend dropped a 350 out of an 87 pick up into his 92 rs and it fit just fine......well i should say the block fit, most of the engine was done over with performance parts but, my guess is as long as its a four-bolt main its good.....but what do i know
<font face="Verdana, Arial" size="2">Originally posted by ironjet:
</font>
Old Jun 20, 2002 | 10:02 AM
RedIrocZ-28's Avatar
Post
Yes it will fit in the bay, but seeing as how it appears to be a truck motor, the power gains would be less than what you desired in my opinion.
Lets put it this way, those HO motors put out some power especially when you put a full exhaust system on it from New headers back. The truck motors had very little power really...Unless you plan to crack open the motor and start replacing parts with high performance stuff, I'd say you'd be better off leaving the HO motor in there.
However, if you do plan to open the motor, I would recommend looking into a new Intake systen and heads/cam package. That would get you some ponies
Old Jun 20, 2002 | 11:43 AM
ironjet's Avatar
Post
ok thats good news , thanks for the info . we're not to concerned with power at this point , just want something that will run so she can drive it . - thanks
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
jj_burchiel
Mar 5, 2015 07:05 AM
89 iroc zl1
Jan 14, 2015 02:18 AM
