Problem..... Damn TPI pain in the F'n A$$.
Old Jun 20, 2002 | 08:10 PM
BlowBye's Avatar
Post Problem..... Damn TPI pain in the F'n A$$.
There seems to be a minor problem. As i was parking at home i decided to pop the hood while the engine was running, and i hear this noise(like someone dropping a bolt inside a tin can) It Seems to happen once every 5-8 sec. I put a magnetic pole right on the center of the timing chain and the noise seems to be coming from there.. Could this be a loose timing chain? I have a Cam button installed with the roller cam i doubt it could be it!? Any guesses?
Old Jun 20, 2002 | 08:27 PM
Shockwave's Avatar
Lounge Moderator
Post
Moving to 3rd gen tech...
Craig
Old Jun 20, 2002 | 10:42 PM
IrocSS85's Avatar
Post
did you torque the cam bolts and use locktite? poss. the cam bolts loose. that would be bad. or, the chain stretched? good luck. chris
G-BODYT56
Jan 14, 2022 11:14 PM
Boss002
Jan 20, 2016 12:17 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
AtlasXVIII
Sep 7, 2015 03:39 PM
