350 blocks
Old Jul 3, 2002 | 09:38 PM
86 redbird's Avatar
Post 350 blocks
I know that a 4 bold main is supposed to be stronger than a 2. I plan on building a mild 383 stroker engine. Would it be necessary for me to have a 4 bold main motor?
Old Jul 3, 2002 | 11:42 PM
Stephen 87 IROC's Avatar
Post
Not really. A 2 bolt main block is strong enough for most street applications. It's actually better to find a 2 bolt main block and have splayed caps installed.
If you can find a 4 bolt main block then use it. For a 2 piece rear main seal look for an 010 casting block. Those are plentiful and the best to use. The 010 casting can be 2 or 4 bolt but if it was out of a truck there's a good chance it's a 4 bolt.
Another alternative for the 2 bolt main block is to have the mains studded. My race engine is only a 2 bolt but with ARP studs.
Stephen's racing page
or check out the race car
87 IROC SuperPro race car
461 big block
Best ET on a time slip: 11.589
Best MPH on a time slip: 115.91
Best corrected ET: 11.114
Altitude corrected rear wheel HP: 457
Best 60 foot: 1.646
Member of the Calgary Drag Racing Association
Old Jul 4, 2002 | 02:22 PM
86 redbird's Avatar
Post
I doubt i'll be running the type of rev's it takes to break a block though will I? It should be a "mild" 383
Old Jul 4, 2002 | 05:06 PM
GMTech's Avatar
Exclamation
From the millions of magazine articles that I have read, it seems that the general concensus is that 4-bolts are only needed if you are running in excess of 500HP or lots of Nitrous or Boost. So for the majority of street applications, 2-bolts are sufficient.
Webmaster:SETHIRDGEN
GM Tech
ASE Master Auto Technician + L1
1987 Trans Am: 357ci
Ported TFS heads, ZZ4 cam, headers & exhuast and other go fast goodies
13.53 @ 103.77
Old Jul 4, 2002 | 05:13 PM
Marc 85Z28's Avatar
Post
4 bolts are stronger, and stronger is always better when it comes to engines. 4 bolts have less deflection therefore better bearing life than 2 bolts. They used them in heavy-duty truck and high performance applications for a reason. If you're going to invest in a 383, might as well spend the extra $/time for the 4 bolt for insurance.
1985 Z28, Jasper Class 1 350, Edelbrock Performer intake, Dual snorkel air cleaner, K&N filter, Edelbrock headers, Catco cat, Hooker cat-back, built 700r4 w/ Darrell Young 2400 stall TC, Jet stage 2 chip, SSM subframes, Lakewood LCA's, Powertrax locker w/stock 3.23's, Centerline Auto Drag's
Old Jul 5, 2002 | 09:39 PM
86 redbird's Avatar
Post
[/B][/QUOTE]
Makes sense. That is the way I will go.
1986 Trans Am. Mostly stock and now FOR SALE to make room for a 4th gen.
240ssLs3
Jul 13, 2015 05:06 PM
camaro02DK
Jul 5, 2015 09:04 AM
geinsteder
May 6, 2015 06:02 AM
jj_burchiel
Classic Engine Tech
Mar 13, 2015 11:20 PM
