Cold Air or Runners???
Old Jun 24, 2002 | 07:45 AM
lil305gta's Avatar
Post Cold Air or Runners???
Which one would I get the best gain from? Which should I do first?
1990 Trans Am GTA 305 TPI-SLP Tranny Rebuild Kit w/ Mechanical Diode,Vette Servo, Transgo Shift Kit, Stock Vette Converter. Flowmaster Exhaust, Edlebrock Headers, 3 nch Dynomax Hi-flo Converter, K&N Cone Filter, TB Airfoil. Taylor Spiro 8mm Wires and Bosch Platinums. Pioneer DEH 4300, Audio control 24XS, PPI 500IQX and 200IQX Sedona Amps, 15 inch Kicker XPL Subs, and Kicker 4x6/6x9.
Old Jun 24, 2002 | 08:13 AM
Damon's Avatar
Post
On a Firebird/Trans AM I'd go with an SLP cold air kit first. It's got a pretty restrictive intake system compared to a Camaro. That's why they're always rated 5-10 HP less than the same engine in a Camaro.
Old Jun 24, 2002 | 09:24 PM
stubbs's Avatar
Post
I agree. The runners are really restrictive on the 350 motors because when the original TPI setup was made it was for the 305 motor, therefore you can understand the airflow restriction on those motors, it wont give as much of an increase on a 305. You will still see an increase granted but I believe the CAI will make you smile a little bigger.
Old Jun 24, 2002 | 10:49 PM
AutoRoc's Avatar
Red face
Runners first. Another vote!
And actually you could make your own cold air intake using PVC and an off the shelf K&N Filter. It would be a LOT cheaper. Paint it however you like and if you take your time it will probably look better than an aftermarket piece. 3" or 3.5", maybe 4" PVC would be awesome. Goodluck man!
Denny
www.denny.cz28.com
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Britbilly
Jan 7, 2015 08:49 PM
Redbird
Aug 18, 2002 02:48 PM
Redbird
Jul 31, 2002 08:20 PM
Redbird
Jul 20, 2002 06:08 AM
