Need help fast!!
Old Jul 3, 2002 | 05:56 PM
Rally Sport's Avatar
Post Need help fast!!
My mechanic just started to install my LT1 cam into my 1992 RS camaro. He just called and said that the lobes are 1/4inch smaller on the LT1 cam then the l03 cam. Is this normal? wont i lose horsepower?? maybe this isnt the LT1 cam?
Old Jul 3, 2002 | 07:40 PM
Post
Anyone have any idea? i have to know if i should go with the cam swap tomorrow or if i just lost 400 bucks
Old Jul 4, 2002 | 12:23 AM
airdeano's Avatar
Post
.250" smaller?? thats alot...
base circle of a cam can make a difference
if the base circle is .500 and the cam lift is
.250 (times rocker ratio is valve lift)
is the same as .300 with a .250 cam lift.
regound cams do this, stroker cams do this
due to the lobe height can strike the rod/bolt
on large lift cams.
valve train geometery will have to be checked
for tolerence and proper rocker alignment.
airdeano
Novo
Jun 14, 2016 02:58 AM
Jeff1904
Jun 5, 2016 05:00 PM
football4life
Oct 4, 2015 07:48 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
damnyankee36
Sep 9, 2015 07:06 PM
