tpi wire harnesses
Old Jun 18, 2002 | 12:06 PM
RPM racing's Avatar
Post tpi wire harnesses
i have an 89 GTA which i bought cheap but the previous owners hacked up the under hood and possibly the under dash harness...trying to bypass the VAT system...they were tweeks for sure...anyways i have a really cool GTA project in my hands now and need harness wires...
my question is: can i use a same year IROC under hood harness? i doubt the under dash harness is the same though...
my friend is parting out a totalled 89 IROC and if the harness to the engine is the same i will grab it...
thanks for any info in advance!
Old Jun 18, 2002 | 12:40 PM
IROC5.7TPI's Avatar
Post
I am assuming that as long as the powertrain combo is the same the harnesses should be too. Another thing is the year and ECM's have to be the same. Check the numbers on the side of the ECM's and if they match the harness should fit fine.
Mike L.
1987 IROC Z 5.7 TPI A4 3.27 Borg-Warner four wheel disc
Mods:
2300-2500 Stall Converter, Shift Kit(GM parts), TPI Specialties Stage 3 PROM, Modified airbox w/ K&N's, Relocated MAT sensor, Gutted MAF, 160* thermostat, MSD 6A, Accel 8mm Wires, bypassed TB coolant, 3" Flowmaster 3 chamber single outlet, custom adjustable cutout, 3" MAC mandrel intermediate, airfoil, ported plenum. !smog, Crane AFPR, Accel rail mounted FP gauge, Harlan shiftlite, 24lb. injectors, Hedman headers, a few others I forgot...??? FINALLY GOT PAINT!!
Check out my IROC webpage!
Jul 4, 2005 05:00 PM
gh0st
Sep 1, 2002 10:24 AM
Teal94V-6
Aug 31, 2002 09:21 PM
CobraEatr
Jul 23, 2002 06:32 PM
