Speed sensor question ( 90-92 700r4 )
Old Jun 21, 2002 | 08:06 AM
90 Z28SS's Avatar
Post Speed sensor question ( 90-92 700r4 )
Can anyone tell me if the speed sensor used in the 90-92 Camaros is a 40 pulse . I have a 700r4 that I am putting in my 95 and I dont want to swap out the speed sensor and reluctor if I dont have too . Somebody told me ALL gm autos used a a 40 tooth reluctor for the speed sensor , can anyone back that up for sure ???
Thanx
Derek 95 Trans Am convertible
K&N fipk , CSI h20 pump , hooker lt's , mufflex 4" , LT1edit , ET streets , 373's , !A/C , !smog
Best Et 12.771@106.89
Best 60ft. 1.820
MTI/GTP stage 3 LT4 heads , cc306 , hyra-rev , 1.6's , r lifters , full manual 700r4 , ST3500 verter , roll bar and more all in the garage waiting for install .
92 Z28 - 5.7/G92 , stock daily driver
Old Jun 21, 2002 | 07:21 PM
funina91ss's Avatar
Post
I am pretty sure they are diffrent from each other you will need to get an a power programer or lt1 edit or speedo recalibration box that is what i had to do when I put a 6 speed in mine but it was and auto. I could be wrong but I think they are diffrent
Old Jun 22, 2002 | 12:09 AM
Kevin91Z's Avatar
3rd Gen Tech Moderator
Post
Whoever told you that is wrong. The 90-92 TPI's use a 4000 pulse speedo signal. I dont know about 93+ 4L60-E's, but I know the T56's use the 40 pulse signal. You will have to change the speedo stuff in the trans to have it work with your 95.
1991 Camaro Z28
350 L98 w/ T56 (originally 305 LB9 w/ T5)
318 RWHP, 419 RWTQ
12.803 @ 108.50 MPH (1.932 60')
Member: SoCal F-Bodies
ThirdGen 4-Life!
Old Jun 22, 2002 | 12:33 AM
90 Z28SS's Avatar
Post
Ok , thats what I thought Kevin I was looking at the 2 and they really look nothing alike . At least I didnt buy the sensor and reluctor for nothing .
Old Jun 22, 2002 | 10:57 PM
IrocSS85's Avatar
Post
hey derek, hows it goin? this is chris, the one who got the front nose.
I have a 700r4 in my 95. you can swap the reluctor and sensor from a 95 lt1 car(4l60E) right in. no mods neccesary. but you do need the auto program in the pcm to go from stick to auto(so the pcm knows how many pulses equal 1 mi.) (the t56 has around 2 times as many teeth as the auto, my speedo would be pegged when i was on the freeway till i got my pcm programed). dont you already have a 700r4 in there though?
chris
1985 Iroc Z, (parting out, email for parts)
1986 Iroc Z, (up and running, but still lots of work to do)
355, ported camel hump heads,750 holley, 700r4, 10.5 compr., forged flat tops, solid cam .501I .510E, 4gen rear w/3:73posi,girdle, and disc's, Edel. torker II, shift kit, 3500 stal, hedmann LT. headers, 4 gen seats, man. strg., lt1 starter, alum. w/p, msd :6al, coil, dist., mallory wires. exp high 12's-low 13's
1995 z28,SS Hood, Iroc style spoiler, tints and black outs, 700r4,2400 act. stall speed,B&M hammer shifter, 17" budnick trilogy III wheels, 275/40 ZR17, 160 stat, man. cooling fan sw., homemaid CAI,1LE elbow, hypertech airfoil, t.b.bypass,!cat, flowmaster, !maf screen, relocated batt., 1LE front l.c.a.s', poly trans and torq.arm bushings, MSD 6AL, custom program, p&p maf, accel coil, and under drive pulley
mods that i have, just not on car yet:
msd wires, edelbrock mid. headers, edelbrock rpm catback
Old Jun 4, 2013 | 04:16 PM
dmtnhwkc's Avatar
Re: Speed sensor question ( 90-92 700r4 )
Check out GM part number 24202711. My Chevy parts guy says the application is listed for Camaros, pickup trucks, GTO's, and many more. It is a 40 tooth reluctor. I don't know if this application is specific to your vehicle, but the parts guy can look it up for you! Hope this helps some!
40 tooth means 40 pulses per transmission output shaft revolution, which means your total pulse output increases as speed increases, thus giving your ECM increased input as speed increases, which is what you want.
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
CaRParts102
Dec 6, 2014 08:45 AM
Jul 4, 2005 05:00 PM
