- Need help with lights!!!
- Is this a good price?
- Power Mirror help.
- Whats the difference between a 92 RS and Z28?
- What should I do?
- How much power
- Setting radio clock on '92 Camaro
- Fuel stabilzer, The car is already away, can I add it to my full tank and start the c
- suggestions...."building" a 350 up?
- Car won't start and more
- Where do I find 1LE products???
- Steering Coloum replacment, how difficult?
- Oil Pan Survey
- need ECM # enlightenment
- V6 T5 gear ratios
- One hell of an oil leak
- Holly 4BBRL on an 86 305 HO
- mufflers
- How much torque does it take?
- The last question...!!! TOP SPEED!
- Fuel Tank Help
- 3rd Gen Gathering.
- 305 TPI guys.....
- LT1/LT4 in my IROC. Has this been done?
- Another First!!
- Should I throw a bottle of fuel stabilizer in my Iroc for the winter ?????
- how much lighter were the 90 and up camaros vs the older ones?
- Ever thrown an alternator belt ?
- Camaro vs Lots of different cars?
- Any one know what this is?
- Crossfire injection on a 82' T/A????????
- quick starter solenoid question
- AUTO or MANUAL
- Please help fast 1988 TBI
- Overlooked 305
- Four wheel disc brake upgrade
- just bought another iroc
- Gaskets!
- Best 3rd Gen to get?
- rear brake lines for 92 camaro?
- How to drain coolant on 350 TPI?
- At the track......
- Need some QUICK help PLEASE!!
- Hypothetically......
- Was tpi an option in 91-92 rs camaros?
- Is my tranny holding me back at the track?
- Well my baby is away for the winter
- What size are the torquex (sp?) bits on the alternator bracket?
- Central Fl V 6 Owners Inside
- slow windows
- Who wants my T/A?
- Light under Center Vent??
- Will 3rd gen and 4th sway bars interchange?
- 305 cam, porting, and stuff... stuff is important you know....
- Porting intake base, plenum, heads
- My alternator Just died what one should I get?
- Best places to buy aftermarket mods?
- true duals
- Rocker arms hitting valve covers
- converting 3rd to 4th gen seats and console>
- How can I find an LT1 engine and comp.
- What is the "Barro" sensor?
- I need some help, buying a IROC.
- "Actual" HP on a stock 305
- shift kit?
- electrical problem
- on & off &on &off......
- Timing?
- Carb question
- Mods
- ADVISE PLEASE LOOK INSIDE all THIRD GENS!
- air pump question
- How does one go about locating a vacuum leak?
- Torque converter
- exhaust
- Help Help Help (y Pipe)
- Where can I get fiberglass doors?
- How many 3rd gens here with LT1?
- BamaZ28, I feel Your Pain
- How much HP does a '88 350 TPI IROC have?
- Joining the F-Body crowd again! '88 IROC
- Help! What Is Happening?
- Needs pics of a rollbar in a 'vert.
- Sprint Springs...?
- Front Window Weather stripping 90 FB
- Seat Belt Stuck
- 350TPI Build, LT1, or LS1?
- Bought new car!!!
- Where is the MAP sensor?
- another head ?
- A4 Stock 87' Iroc 305 Cam specs?
- Now for the 305 Question! :)
- head ?'s
- Questions about Compression vs Octane Rating
- Y have my times not improved?
- Steering Colomn, need help with high-beam switch
- rear end in 1991 RS
- Th700r4
- I hate 305 bashers!!!!!!!!
- pistons rings
- STB....3 or 2 point?
- Thinking about buying a 3rd Gen...
- RamJet on a 5.0L 305?
- GM fast burn vs Edlebrock E-tech 200
- IROC-Z what should I upgrade to?
- Alternatives to the 700r4 in an F-body -- Questions within...
- 9 Bolt Posi Needed
- 88 Trans Am F/S
- IROC 3 spoke steering wheel question....
- t-56 swap: use LT1 bellhousing? or aftermarket one?
- ?s about my old 3rd gen sitting around...
- Scat cranks who uses them
- when did they start putting 350's back in Camaros
- Hatchback Motor Question...
- 305 TPI? What's your best E/T?
- help....
- Maf options
- Hom much advance does computer have???
- Stuped question
- Help Needed!!!! Experts inside!!!!
- How to jumpstart my 83 Z28 off my '99 Mirage?
- 9 bolt rear rotor and caliper questions
- Comp. Ratio
- TPI wiring
- Stroker Kit? Explain to me?
- which intake
- tuned port on a throttle body??
- Melting question!!!!!
- Aluminum L98 Heads
- Too Cam Or Not Too Cam
- Shoping list for TH700R4 stuff
- LG4 to L98(or similar 350 TPI) SWAP!!! WHAT IS NEEDED/INVOLVED?????
- Holley Stealth Ram Intake
- starting troubles
- Help, Headlights Don't Work!!!!!!!!
- 3rd gen part left from parted out car
- anybody use Lt1 mass air on a tpi
- Service Engine Soon
- th200-4R into a third gen, how to, is it possible?
- Vats
- I hate my starter(s)
- whitch gearbox will should I buy?
- my buddys 305
- need help with a hood
- Taillight/Brake Light Problem...???
- tranny change
- running rich
- Micro Fiche???
- I want a 3rd gen What should I get
- No power steering cooler?
- What can I stroke this stock block to?
- Dumb IROC Z28 question.
- What are all the differences between a 3rd gen IROC, Z28, or RS?
- Motown crate motors
- gauges
- Attn.. All 3rd Gens with Strut Tower Braces..
- Single plane intake under the stock hood
- Steering colounm going loose, how to fix it!!!
- tps voltage?
- PLEASE HELP! Odd..... "clicking noise" coming from pass side head area.
- Tremec T56, T5, TKO Service Manuals within
- Autometer Triple Guage Install
- Electric Water Pumps, Anyone using one? streetable?
- AFR flow numbers
- Check ouy MY website (Updated) no popups
- Serious Tech Question For Ya'll...
- is there anyone or any business that stretches rims
- Do they still make these
- Anyone know of any decent 3rd gens in Mich for under $3500?
- Which Engine?
- how much could i get for this setup
- camaro weight?
- Think I fixed the ticking/please confirm my method
- theory behind my slowness....
- t-56 in a 3rd gen
- torque arm bolts
- Car idling awful, bad vibration etc, need help
- Calling all TPI guru's
- Slow Signal Lights
- The on-going saga of my luck!!!!
- Gears selection
- Help!!! Suspension Q's
- Can you convert to 4 bolt mains from 2?
- Fireballlll!!
- installed the Transgo repgram kit, have questions
- FP Reg help bigtime?????
- Burnout Videos I finally got online
- HEI in my 87?
- vortec heads on 305?
- Check out the vid for my new motor!
- 91 speedo w/TH400
- Whoo hoo TPI problem Hasnt Resolved....
- Oil pressure
- Who wants a K-Member?????
- best way to tell it's 350
- Need input on engine.
- Can i change my gauges?
- Converted to non-computer carb setup and aving trans/idle problems..
- Got car back with LT1 intake on my 305
- Where can I find a Parts List for 1990 ?
- edelbrock torque arm owners inside.......
- Getting more mph out of my setup tomorrow...?
- Rate my new motor!
- need a little favor guys.
- TPI Intake for the GM 350 HO
- Update on the new motor!!!
- Winter Tires, what size for 16x8" rim?
- Hatch Squeek, how to fix
- When braking in a new engine
- New engine barely runs...
- is 625cfm to big for a 305?
- 1987 iroc fusebox, HELP!
- Thinking about 89 IROC-Z, have questions
- Disasembling a TH700R4 with engine torque
- Tires
- Headlight/Tail Lights
- Line Lock Install, need help bad!
- 86 t/a 305 tpi rearend 3.27
- Nice car, but the engine needs new life!
- Nice Car, but the engine needs new life!
- 3Gm 350 HO
- Need some help with a leak.
- Crate vs. custom??
- What tranny is in there probably
- BEST SOUNDING 3rd Gen
- '85 LG4 check engine light on
- Help!!!!!!!!
- sub frame connectors
- T-5 Question
- Anybody know anything about Pro-Am Firebirds??
- 350 Motor swap
- My friggin luck!!!! and a question!!!!
- Roll Cage, Did you install it?
- Intermittent Wiper Function 90FB
- Need some Info on what this spolier is off of!
- Body Restoration
- Timing vs. MSD 6AL
- Disgruntling "pop" coming from front end..... Pease help!
- mallory fuel pressure regulator
- anyone using an electric water pump
- Need help on wheel/Tire size
- How bad is plug install on a V8 RS?
- hesitation problems.
- WS6 Center caps
- will factory roller lifters work on Accels High lift cam?
- heater core...dun dun dun
- Whats the timing set for early TPI's?
- 1988 VIN Decoding
- Ignition Module, limits and benefits
